Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 100
  1. #51
    Oct 2010
    Lake Wylie NC Area
    Does that mean that the pump has leads off of it?
    Not yet, will do it today.
    If I am drilling one hole, might as well drill two.
    Eric.
    The pump has leads about 10" long and the switch has a pre-wired connector with pigtails about 8" long. It does not include an actual wire harness, you still have to run two wires from the switch to the pump and from the switch to your battery source.
  2. #52
    Portland Oregon
    Eric.
    Looks like the WM kit has the switch included.
    -Jake
  3. #53
    On a NorCal Lake Somewhere!
    I thought I would have completed my order from WakeMakers by now, but I haven’t heard from Bryan in a couple of days, so I figure he has;
    1. Gone snowboarding
    2. Taken off to go see family for Thanksgiving
    3. Had a major email server crash
    4. Is WAYYY TOOOO busy at work
    5. Woke up in jail asking his buddy “Where did this tattoo come from…”
    6. Is tired of reading and answering my long winded, incessant email questions presented in bulleted form
    But I now know (I think) what I want to do, which is;
    A. Use the existing Rule fill pump and switch it to only the front ski locker bag
    B. Change out the front ski locker bag dump pump to a 1100 Aerator
    C. Add two new Jabsco reversibles for the rear bags
    a. Add two new under boat water pickups
    D. Add a cross-over pump for the rear bags
    E. Change out all three bags for new ones with quick connect fittings
    F. Add new switches as I want to get rid of the stock location and change out to the contura style switches and mount them up higher
    1. And is there still a discount for being a Moomba forum member? I hope so, as I figure you guys are responsible for me spending the $$$
    This is what I think I need to order, could you please help/comment on the items below;
    1. Two (2) - Jabsco Reversible Ballast Pump kits for the rear bags
    2. One (1) - Jabsco Ballast Puppy Premium Impeller Green (6303-0107) as an extra for the glove box
    Use the existing Rule plumbed to only the front center locker bag
    3. One (1) - Rule 1100 Aerator pump (short) - This one will be to change out the front ski locker bag dump
    4. One (1) - WakeMAKERS.com Exclusive X-Link Quick Switch Ballast System
    5. Two (2) 750 sacs for the rear - Fly High Pro X Series Fat Sac
    6. One (1) bag for the ski locker - Fly High Pro X Series Tube Sac
    7. 3 new switches & covers –
    a. Each of the Jabsco pump kits come with a new switch
    b. Does the cross-over Kit come with a new switch?
    c. I need a new switch for the Aerators that will be for the front ski locker bag – Is this a DPDT?
    d. One for the Stereo amps – Is this a SPST?
    e. one future - Probably a DPDT
    8. Will I need new hose for the now straight shot from my existing rule fill pump to the new center bag?
    9. Do the bags (2) 750s & (1) ski locker bag come with quick connects?
    Thanks for any help, Eric.
  4. #54
    Oct 2010
    Lake Wylie NC Area
    Aerator pump switch: You needed a 3 position latching ON/OFF/ON switch. A DPDT will work fine, but a SPDT is at least needed.
    Stereo remote turn-on switch. A simple ON/OFF SPST is all thats needed. If you helm has an unused rocker and it happens to be a DPDT, now sweat, it will work fine, you will just use the center post #2 for your B+, which is probably already hot, and the bottom terminal #3 for the switched output to your head-units red wire.
    No, the standard Fly High bags are not packaged at Fly High with any hose fittings included. The standard sacs only include 1 W730 Quick-connect that mates with the W709 pump kit, some W731 Wally Plugs and 1 W749 Air air vent cap.
  5. #55
    As for Bryan at WM he has been working from home and im sure very distracting as hes a New Daddy now. Congratz to him and his Wife.
    If you have any trouble getting your order done let me know ill call Spence and push it threw.
    Also Yes you still get a Moomba Discount, just remind them and they will add it to the bill.
  6. #56
    Now that is a reason not to reply!! Congratulations to Bryan at WM!!!
    I will call Monday (and ask for Spence?) and order the following;
    Use the existing Rule 1100 fill pump and replumb it to only the front center locker bag
    5. Two (2) 750 sacs for the rear - Fly High Pro X Series Fat Sac - Yellow
    6. One (1) bag for the ski locker - Fly High Pro X Series Tube Sac - Yellow
    a. Each of the Jabsco pump kits comes with a new switch and cover – I will ask for one cover marked “Left Ballast” and one cover marked “Right Ballast”
    b. One new switch for the Aerators that will be for the front ski locker bag –SPDT with cover marked “Front Ballast”
    c. One switch and cover for the Stereo amps – DPST to kill the amps by relay and kill power to the head unit
    d. One future switch and cover - Probably a DPDT
    8. (6) Ballast Rocker Switch Mounting Panels
    9. 20’ of 1” ballast hose for the now straight shot from my existing Rule fill pump to the new center bag
    10. I will ask WakeMakers
    a. if I need any additional fittings for the bags, pumps or whatever
    b. if the Ballast Cross over system comes with a switch and cover
    And after the big brown truck drops everything off at my house, I will wrap it all up and tell my wife that her Christmas presents came early!!! Kind of like the year that I got her a bright shiney new blower and EFI that happen to fit my Schiada that I had at the time!!
    Thanks for the help guys. Eric.
  7. #57
    List looks good, but don't forget all the hose clamps or, IMO the better option, the crimp tool and crimp bands.
    And, why 750's vs 1,100's?
  8. #58
    ...And, why 750's vs 1,100's?...
    Didn't think they would fit in my ol '02
    Eric.
  9. #59
    Doesn't sound like much hose - you reusing what you've got? I believe I put around 80-100ft of the stuff in mine when I did it and used all but about 3ft worth...
  10. #60
    Doesn't sound like much hose - you reusing what you've got?...
    No, the only thing that I am going to be reusing is the Rule 1100 pump that currently fills all three bags (I think)
    All new hoses and clamps (since I haven't found one clamp yet!)
    The reversible kits come with 20' each, That would put me at 60' hose not including whatever comes in the cross over kit.
    Eric.
