Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Ballast vents
    Default Ballast vents
    Just thinking out loud after reading Dazes lsv mod thread regarding rear hatch size.
    My 1100 surf bag pops the hatch, any reason I cant vent the bag from the rear of the bag instead of on top.? I have the reversible pumps with one way check valves on the vents! May save me two inches on top of the bag.
    Jul 2011
    Murrieta, CA
    Where is the vent on the rear of the bag? Top or bottom. A top side vent will burp the air out more effectively.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Oct 2010
    Lake Wylie NC Area
    What kind of check-valve is in the vent? Some require a little bit of pressure to open. This allows the bag to bilge a little.
    Quote Originally Posted by Boonejeepin View Post
    I am not even drinking, just looked at the bag ports on WM and they are both on top..
    Never mind, I must be in a fog. I just hate the way the 1100 pops the rear hatch... Errrr.
    It's a wake makers check valve.
    http://www.wakemakers.com/marine-check-valve.html
    Oct 2010
    Lake Wylie NC Area
    If the vent line is on the top, then take the check-valve out temporarily. This will allow the sac to vent more freely. It will not raisin on its self during draining like it does with the c/v in place, but it should still have a fairly complete drain with the impeller pump.
    Without the cv, the bags dont suck flat , with the cv it's like the space age vacuum bags.
    I guess I have to get the timer right so it won't pop the hatch, I prefer the suck flat bags in the rear.
    Sugar Land, TX
    My 2011 does that too Joe, annoying. Did you add the check valves? I think I might have to do that. Do you just cut the hose and put them inline, close to the bag or the exterior port?
    2011 Mobius LSV
    Ron
    Quote Originally Posted by rca View Post
    Ron,
    Simple install. I cut the vent lines a few inches from the thru hull in a spot where it would be close to, and held out of the way, by a zip tie. Cut the line, slip on 2 hose clamps on each hose end, twist the hose ends on the check valve and position & tighten the clamps.
    Enjoy a beverage, or two.
    I'd be hard pressed to get rid of the check valves. Do the bags pop the hatch b/c they are ballooned with air?
