Results 1 to 1 of 1
08-12-2005, 08:24 PM #1Junior Member
- Aug 2005
- 4
Delay between turning key and starter engaging
My 99 Outback with a 310hp PCM 5.7 has a delay when trying to start it. Especially when cold there is a delay of 5-20 seconds. I turn the key to start, Hold it and sometimes it does nothing and other times it turns over after about 5-20 seconds. The motor fires right up. I have a new battery and a new ignition switch. Sometimes it starts normal if the engine is already warmed up. I had a starter guy check out the starter and it seemed to be fine.
Has any one else had this problem?
Thank you in advance.
Bob (gdyupngo)
delay ordering on boat because there is noise and vibration
By On Board in forum Service & RepairReplies: 7Last Post: 11-06-2007, 04:29 AM -
FULL SPEED turning
By shulaj in forum General ChatReplies: 4Last Post: 10-03-2007, 10:43 PM -
Vibration turning to right when pulling
By bergermaister in forum Service & RepairReplies: 20Last Post: 08-27-2007, 05:35 PM -
Boat not turning unless in gear
By clark in forum General ChatReplies: 8Last Post: 03-10-2005, 08:08 PM -
Starter
By wdf in forum Service & RepairReplies: 0Last Post: 08-10-2003, 10:33 PM
