Results 1 to 7 of 7
    Sep 2010
    Dallas, TX
    Default Pro Charger Question.
    Since the day that I have turned the juice on to my charger, except for that day alone,,I have not seen it charging once?? The blue light stays on 100% of the time?? This is after leaving amps on and leds for long period of times. Im confused on this one. Jet
    89' Comp Resto:
    http://supraboats.com/bbs/showthread.php?t=8193
    Riding and Mod pic's:
    http://www.supraboats.com/bbs/album.php?albumid=86
    89' Supra/Custom Tower & Interior/Swivel Racks
    4 Blade-14X14/1600 lbs Ballast
    Roswell Bar/Led's/Krypt 6.5 HLCD's/Krypt 4200 Eq
    JL-PPI Amps 1750 Watts/Kicker Interiors/L7 Kicker Sub
    Henderson, NV
    can't answer your question as I have just installed mine and have not turned it on yet, but I will say that is a very clean install
    May 2011
    Flower Mound, TX
    Not trying to hi-jack Jet... but what is the function of these? Are they needed if you have 2 or more batteries?
    '08 Mobius LS. Sold
    '18 Craz "TypeO"
    REV10's, Revo6 xss, Kicker10, Kicker 12 CompR, various LED's
    Oct 2010
    Lake Wylie NC Area
    Jet,
    If you have a digital multi-meter, its easy to see the charger working. Unplug the chargers 110V A/C cable, turn your stereo on and take voltage reading from which ever battery is supplying the stereo. Now, leave it playing for about 10-15, or a little longer if time permits. When you return, take another voltage reading. The 2nd should be lower then the first. Now, plug the chargers A/C cable back in and watch the volt meter. You should see the voltage start to climb, indicating that the charger has sensed the battery is down and needs charging.
    I would also double check to make sure your charger is set for the correct type of battery you have. This could color coated inserts that need to be swapped.
    Chawk,
    A battery tender/maintainer can be great for any boat that has a long winters nap or sits for extended time during the season. The size or number of batteries doesnt matter in this as its more about keeping the batteries conditioned while not in use.
    Now, for those with heavy load stereos and large amp hour stereo banks, a charger is almost a must in order to replenish the batteries after each use. Reason being is that alternators make for poor battery chargers. It takes a lot of run time for an alternator to recharge a depleted bank of batteries. A charger works much more efficient and while the boat rests in its home spot.
    Sep 2010
    Dallas, TX
    Thanks sandm. I am back to work on her finally. Chawk610..its a pro charger just plug it in when you get home and it keeps the batts topped of and cycles them. I have had batteries go dead from just sittng and this keeps them active and charged 100%. With the stereos we are putting in our boats now days its a must have! If you take your boat out sat-sun you can bring your boat home with the batteries 1/2 charged or worse then if you go back out sunday your starting the day off with low batteries..this cures those kind of probs. Jet
    89' Comp Resto:
    Aug 2011
    Use a voltmeter and see if the batteries are charged...
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV - Sold
    Mar 2003
    Springfield Missouri
    Every battery maintainer I have had will go into a charge when a substantial load is turned on. With no loads, I never see it in the charge mode except when it is first connected.
    1998 Mobius
    310 HP PCM
    SOLD
