Results 1 to 10 of 11
Thread: Muffler
    Sep 2011
    Onsted, MI
    Default Muffler
    Was winterizing my 2011 Outback V. Pulled the drain plug in the muffler. Went to put it back in and it stripped out. Any good ideas for a fix?
    Portland Oregon
    Any pics? Is it just a plug in the cast iron? Cast iron plug too?
    -Jake
    Muffler should be fiberglass, just get a slight larger thread size and it should screw right in
    Jul 2002
    London Ontario Canada
    ^^^^^^ what he said
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Sep 2011
    Onsted, MI
    It is fiberglas. Can't tell if its reinforced with a nut on the inside or if the threads of the bolt just cut into the fiberglas. I'll try a larger screw and report back.
    Mar 2003
    s.e. washington state
    Glad we don't need to drain the mufflers on the DDs. I'd have to remove the engine cover, three rear panels and the floor to get to them. I did it once this year to tighten the gland nut. I do blow out quite a bit of water when I turn over the engine with the coil removed.
    1998 Mobius
    310 HP PCM
    Zabooda thats a lot of work LOL.
    Its not to hard on the V drives, its sits in the front of the ingine and you open the panel to the port locker and the drain screw is right there on the edge. The biggest pain is when changing the impeller, its muffler is right in your way.
    Aug 2008
    Jeff,
    I have the same issue on my LSV, did a larger bolt work? the original looks to be 1/4-20 size bolt.
    Alabama
    Quote Originally Posted by Paul View Post
    Jeff,
    Paul,
    did you find a solution? I just had the same thing happen with my LSV muffler drain screw.
    Dec 2006
    Tuscaloosa, Alabama
    Careful now. My drain plugs on my block are 1/4" pipe thread. I had to retap it two weeks ago. Cross thread the brass plug. Just ran the same size tap in the block and a new plug. Good to go.
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
