Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 181 to 190 of 197
  1. #181
    Default Mojo Surf Ballast Setup
    Calling now.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  2. #182
    Jul 2013
    Fort Worth, TX
    Thanks Drew.
    2013 MOJO
  3. #183
    Quote Originally Posted by NateHaskovec View Post
    Just to remind you, if you put a check valve on the ibs vent and you have a hard tank, the hard tank won't drain.
    You need air to get in the tank to pump it down.
    Either a backwards check valve or a vacuum breaker needs to be on the vent line close to the tank.
    That's right !! That's why my center hard + IBS are full when only 60% is displayed !! In fact, my tank never drain... But I don't understand where you want to put an other valve...
  4. #184
    Jul 2010
    Vicksburg, MI
    The following link is a fix for the center hard tank and IBS draining problem.
    https://forum.moomba.com/showthread....202#post199202
    The spring loaded check valve acts as a vacuum breaker.
    https://forum.moomba.com/showthread....411#post208411
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
  5. #185
    Aug 2013
    Richmond, VA
    Any idea on where and exactly what spring loaded check valve or vacuum breaker to get?
    Rusty
    2013 Mojo
  6. #186
    Jul 2013
    Charlotte, NC
    Quote Originally Posted by rbeckner27 View Post
    Ever find the answer to your question? I'm curious as well.
    So I've got the shopping cart ready and waiting. Can you guys tell me if there is anything else I need for the IBS install in a '13 LSV? I think I've got everything covered. Thanks for all the help!
    2013 LSV
  7. #187
    Aug 2013
    Richmond, VA
    Was told Home Depot but i haven't checked yet.
    Rusty
    2013 Mojo
  8. #188
    Jul 2010
    Vicksburg, MI
    I plan on using this plastic spring check valve as long as the threads match when I install an IBS in my new LSV.
    http://www.doitbest.com/Main.aspx?Pa...=435808#online
    It is available on EBAY and Amazon also.
    Joe
    2014 LSV
    1993 Echelon
  9. #189
    Nov 2003
    Land O Lakes, Florida
    on my IBS install, I took the vent line from the infloor tank and cut it about 6" after coming up thru the floor infront of the driver, add a Tee fitting, one side of the T goes to the IBS lower port, the upper port goes to the vent thruhull on the side of the boat, this has a wakemakers inline check valve. On the other side of the T I ran a line up higher than the vent thruhull and added a spring check valve from Ace hardware or from Home depot-had it a few years and just don't remember where it came from. When the ibs is full it will flow out the vent thruhull. when empting the ibs will dang near drain 99%, then when the vacuum pressure hits a certain point the spring check valve will open and let the infloor tank drain about 90-95%, then when im on the ramp pulling the boat out I have my wife hit the empty to finish the job on all 3 bags as there is allways some water left. anyway this is how mine is and it seams to work pretty good-all automated, no valves to mess with. hope this helps, if any questions feel free to ask
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  10. #190
    Nov 2003
    hitboost, not sure where your planning to use the Bosworth valve, other than that your shopping list looks good
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
