Page 13 of 20 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 197
  1. #121
    Hi, just installed the new ballast today. For the 1" TH I have to enlarge the stock holes (didn't take tool to do it). We tested (only 1 driving and 1 surfing). Speed was 15km/h (9.4 mph) max otherwise the wave become dirty. Wakeplate 3/4 up. Starboard ballast 20%. How much did you put in your starboard ballast when wakesurfing ? Did you fill 100% the IBS ? The lake today was not flat at all so maybe it's not the best to test. We will test again tomorrow with more people onboard. About the propeller, did you change it?, it seems the boat as much more difficulties to move all that weight compare to stock ballast !
    Timer setting (aprox) Left 13min (1100+370), Center 11 min (stock + IBS) & Right 11min (1100)
    Thanks for feedbacks
    p.s : my hands are ruined with these damned hose !! even with heatgun !! Especially the "Y" connection !
    2012 Moomba Mojo 2.5
    ACME 1235 prop
    Wakeboard Hyperlite Belmont
    Wakeskate Hyperlite Byerly
  2. #122
    gurt, I surf with port locker 1,100 full, 370 port full, center full, IBS full and starboard locker 1,100 about 25-50% and @ 11.1 mph with the wakeplate anywhere from 1/4 to full up. The wind and water conditions can impact the wave, but I'm normally able to clean it up pretty easy. I upgraded the prop from the factory and have the 345 hp motor & have no issues at all getting moving.
  3. #123
    Feb 2010
    Canton, Ga / Lake Lanier
    Quote Originally Posted by drifter View Post
    I'm thinking of doing close to this same setup in my 2012 LSV. I would add the 2 1100s in the rear lockers, and an IBS. I would also upgrade the vent line from the center bag to 1" so it could fill the IBS. Is there anything else I need to know?
    Thanks
    That's what I run in mine with the addition of a 400 under the side seats. I do not fill the opposite side at all. I've found that does NOTHING to help IMO.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  4. #124
    for the LSV, I tend to agree. for the Mojo, it needs the off side weight.
  5. #125
    Jul 2009
    Cleveland, Tn
    I used the upgraded clear tubing with the black plastic embedded. I place the end of the tubing in boiling water for 30-45 secs and it becomes very flexible and slides over connections with minimal difficultly.
    2012 Mojo
    2009 LS (SOLD!!!)
    2010 Tundra 5.7 Crewmax 4X4
  6. #126
    Hello Wolfman, thks for infos. So your prop comes from moomba? I saw some prop from wakeprop.com
    Did you remember the model that you have? thx
    I don't have issue but it looks that an other prop would be better..
    ACME 1235 prop
  7. #127
    after replacing the prop, did you have to calibrate something because speed at same rpm change or is there a sensor that doesn't depend from prop?
    ACME 1235 prop
  8. #128
    Drew has the Acme 1235prop, I do too. nothing to recalibrate, bolt it on and go.
  9. #129
    Jul 2009
    Cleveland, Tn
    I think most everyone on here with a Mojo has the 1235 and it does the job without complaint!
    2012 Mojo
    2009 LS (SOLD!!!)
  10. #130
    Dec 2012
    Ennis, TX
    Quote Originally Posted by Salyers View Post
    That is correct. 1235 has no problem even at 5K of ballast.
    Shane
    2016 Supra SE
    EXILED
    6 XM9 Tower
    6 Wetsounds XS650 Cabin
    1 XM 15.4
    XI 1500.1
    2 MX 30.2
    Wetsounds 420 EQ
    EXILE Blue tooth EXBT4
    Blue LEDs
