Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Feb 2012
    St. Albert, Alberta, Canada
    So I got my valve installed.
    Moved my pumps as well.
    2010 MOOMBA LSV
    340 CAT
    ACME 1235
    3100#'s
  2. #12
    Nov 2003
    Land O Lakes, Florida
    looking good so far, make sure to report how it all works
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  3. #13
    Looks good! If you can, try to tilt that pump mounted to the panel so the pump head (where the hoses attach) is a little lower. That will help extend the life of the pump.
    The Y Valve is a great way to add a lot of control, without the expense of additional pumps. A passive system (with a Wye) works just fine if you don't need control over which bag fills.
    WakeMAKERS | WakePROPS | WakeSOUNDS | EasyBoatCare
  4. #14
    Feb 2012
    Default How did you plumb your IBS???
    Quote Originally Posted by jasonwm View Post
    Looks good! If you can, try to tilt that pump mounted to the panel so the pump head (where the hoses attach) is a little lower. That will help extend the life of the pump..
    Thanks!
    What could happen to the pumps? This is how the factory mounts them....
    2010 MOOMBA LSV
    340 CAT
    ACME 1235
    3100#'s
  5. #15
    Feb 2010
    Canton, Ga / Lake Lanier
    Quote Originally Posted by lsvboombox View Post
    I ran the mastercraft y valve like you are planning. Main lin e in one line to the floor sac then i bought a y splitter(not a t) and ran one line to each leg....
    That's EXACTLY what I'm going to do.
    Distribution Manifold
    This is what it will look like when I'm done. Going to have 3 just like this in the regular side locker...
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  6. #16
    Quote Originally Posted by KRAK View Post
    Thanks!
    Mounting the pump horizontally like that can potentially lead to failure of the bearings and or brushes. It's unlikely, and typically only happens when the pump head is higher than the motor, but it's cheap insurance to prevent having to replace a $200 pump, because it's usually after the warranty is over that it fails.
    Sounds like a good plan, post some pictures when you're done.
  7. #17
    Nov 2003
    Jason, in the photo above with the 3 pumps, which one is mounted correctly ?
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  8. #18
    Well, technically none of them are mounted wrong, since the pump head (where the hose connects) isn't above the motor. But we would prefer it if pumps were installed with the pump head below level with the motor. Based on that, the bottom pump is mounted correctly.
    Watch our product video on the Jabsco Ballast Puppy Pump for more information, I talk about installation at 2:00 in.
  9. #19
    Nov 2003
    Good news as that is how I remounted all mine, plus if one goes bad Ive got a spare in the box
    still going to watch the video tho
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
