Results 1 to 3 of 3
Thread: bad gas
08-06-2005, 11:46 PM #1Junior Member
- Aug 2005
- 3
bad gas
I am writing to see if anyone here knows the key to remove a gas tank from an 01 moomba outback. I have gotten a hold of some bad gas & it has led me to replacing a h2o separator twice, rebuilding a carb. & with no luck there, my only hope is to remove gas tank & clean it. Any suggestions on removal & cleaning? Please help! moombadog-
08-07-2005, 03:28 PM #2Junior Member
- Aug 2005
- 3
Replying to Topic 'bad gas'
Jeff,
Thanks for the reply. I have tried running the boat in the driveway w/ small amt of gas w/ additive. When I do a gas sample by dumping the h2o separtor I still have residue in the gas. This is why I need to remove tank. Thanks for the suggestion. Please let me know if you have any info on removing the gas tank. Thanks Michael
08-08-2005, 12:47 AM #3
Run the gas out using the fuel pump and disconnect the line after the pump and run it into gas cans. Run a power source to the connections on the pump and then power the pump so not to have a spark.
1998 Mobius
310 HP PCM
SOLD
