Results 1 to 10 of 12
09-26-2012, 12:05 PM #1
Minor thing: the drain for the ice chest
Just a little thing, but it bugs me a little...
We used our ice chest, and later there was water all over the carpet underneath the sets. Water was getting underneath the drain instead of going through it, so I figured, hey, just seal around the drain with silicone and it would be fine.
Well, in the process of doing this, I took the drain out, and it's not connected to anything. The drain outlet is just sitting flush with the carpet underneath the cooler. I could tell there was a hole under the carpet for this water to drain into, so I just poked and drilled at the carpet until I made a hole through it.
So I guess two questions:
1) is everyone's boat like this, or did SC just forget to make the hole through the carpet?
2) where does the passage that this water is draining into go? Does it go back to the bilge, or does it dump into the cavity under your floor where the gas tank is (where water is very hard to get out of the boat!) Maybe this is one and the same...===================================
2005 Moomba Mobius LSV
09-26-2012, 12:36 PM #2
My "cooler" (RIP) drained through a hose down through the hole in the floor. Where it goes, nobody knows.
09-26-2012, 01:07 PM #3
It does drain to the Bilge, when we used ours the first season when i drained it shortly after the bilge comes on. Mine has since been removed because the cooler never worked and i rather have the storage. There is a hole threw the carpet and the drain tube just ran threw it and hung there.
This is a bilge chanel of some sort, but it does goto your bilge area.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
09-26-2012, 01:18 PM #4
OK. Mine didn't have any hose, it was just the plastic fitting that is the cooler's drain. I guess I should put a short length of hose on it to better direct the water into the "channel" that takes it off to the bilge. Or just don't worry about it.
Or just cut out the cooler like some people have done here My wife likes the cooler though.===================================
09-26-2012, 01:40 PM #5
IM leaving our cooler. Love it.. We put the plug in it and dran it when we get home. Pull the center plug and pull plug on the cooler.
Chris H.
2012 Mojo
Wake Life
09-26-2012, 05:23 PM #6
She might love it now but the reason people remove it is because about 2 hours on the water and all the ice will melt. Its not insulated at all and sitting at the water line the heat from the lake actualy makes the ice melt faster.
C Hern im expecting and hopefull the cooler in the new Mojo was made a lot better then in the privious years.
The only other Moomba i have seen is the XLV with a decent little cooler in the floor and it keeps ice and drinks pretty cold for a long time.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
09-26-2012, 05:27 PM #7
09-26-2012, 05:35 PM #8Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
09-26-2012, 09:08 PM #9
Sorry to take this thread in a different direction with the removing of the cooler. As far as the drain on my 2010 goes, it has a length of 3/4" tubing attached to it and it runs back and dumps into the engine compartment.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
09-27-2012, 08:44 AM #10Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
