Results 1 to 3 of 3
    Jul 2010
    Vicksburg, MI
    Default Transmission Screen Cover Wrench
    Since it seems like summer is over up here in Michigan, I decided to change all the oils in my boat today, and attack the transmission screen for the first time. I followed DOCDRS Transmission and Vdrive post, but I found a minor issue with it. The two bolts that hold the transmission screen cover plate are metric, and therefore require a 13mm wrench, not a 1/2 inch wrench. In some cases a 1/2 inch wrench may work, bot not in all. I do not know how long the transmission has been using metric hardware, but it is definately metric in the 2010's. I was going to add this to DOCDRS post, but it is closed. Hope this helps others that have tried.
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
    Very thoughtful of you to post on this. How did it all work out for you?
    Jul 2002
    London Ontario Canada
    Thanks and the post has been updated
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
