Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
    Coming from a dorky profession myself, i read Davids comment as one dork telling another dork he made a calculation error.
    I did read it and know it would bring criticism, though. I mean half of America is cool with being fed non factual info, right
    But Mike, although often too technical, i appreciate the balance here and even the learning experience.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Sep 2009
    newnan, GA
    Xm9's on the outsides of the tower now and add some xm7's towards the center later on.
    2005 mobius lsv
    ga,
    I'm not crazy about mixing a 6.5" and 8" speaker on the same tower. Here's why. The SD (effective surface area) of the smaller XM7 is a little more than 19 sq.in. The SD of the larger XM9 is about 38 sq.in. Doubling the surface area usually results in a difference approaching 3 dB. Side by side I can tell you there is a big difference between the two. To put +3 dB into perspective that is equivalent to doubling the amplifier power. So here lies the challenge. You would need twice the power for the XM7 to reach the same amplitude as the XM9. That places the XM7 in a vulnerable power handling position. Or, you allow the XM9 to naturally dominate the XM7. In that case you have invested alot in additional speakers and power to only have a very modest increase in output. I have to recommend staying with symmetrical sizes whenever possible, especially in a one on one scenario.
    Feb 2012
    St. Albert, Alberta, Canada
    How low do each hang below the tower? I can't find dimensions on the Exile web site.
    2010 MOOMBA LSV
    340 CAT
    ACME 1235
    3100#'s
  5. #25
    Jan 2010
    North Texas
    xm9
    Hanging Height: 10.5 inches (266.3 mm)
    Speaker Height: 9.9 inches (251.2 mm)
    Width: 10.0 inches (253.7 mm)
    Depth: 10.2 inches (257.9 mm)
    Hanging Weight: 10.8 pounds (4.9 kg)
    xm7
    Hanging Height: 10.25 inches (260.35 mm)
    Speaker Height: 9.0 inches (228.6 mm)
    Width: 8.875 inches (225.425 mm)
    Depth: 9.5 inches (241.3 mm)
    Hanging Weight: 6.7 pounds (3.04 kg)
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
  6. #26
    here is a pic of mine not sure it helps as there are off to the side on a v2
    Looks sharp JM. Those towers leave lots of headroom!
    2016 Moomba Mojo
  8. #28
    except with the playpen, i had a hat on and did not see the tower coming from the bow and almost knocked myself RTFout....it hurt and saw stars, the v2 is SOLID
    Quote Originally Posted by kg's supra24 View Post
    looks sharp!
    agreed!!!!
  10. #30
    Sep 2009
    newnan, GA
    ga,
    Gotcha was mostly considering head room
    2005 mobius lsv
