Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Quote Originally Posted by patrick232 View Post
    I'm looking at a leftover LT with the 3.42 rear end and a Yukon with a 3.08 rear end.
    I have 3.42 gears, granted mine is a bit older, and they suck ass for towing. That was before I went to a bigger tire, making them even worse. Unless you like driving around in 2nd gear all the time - including some hills out on highway/freeway - I'd go min 3.73's.
  2. #12
    Pensacola, FL
    The 6 speed tranny really helps out in the newer GMs. I have the 3.42 in my Avy and it tows just fine. As with anything, you will always want more power.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
  3. #13
    Aug 2008
    Hilliard, Ohio
    I know the 3.42 is the way to go, since it's the highest they put in it.
    Here are the 2 trucks
    http://www.coughlincarsgroup.com/new...eebdb5b44f.htm
    http://www.youtube.com/watch?v=KKS33...ature=youtu.be
    The GMC does look sweet.
  4. #14
    15 qts of synthetic and filter only run you 100 bucks? I'm out almost 80 for 7 qts and a filter for my truck.
  5. #15
    Sep 2009
    newnan, GA
    I work at. Dealer and that was $150 for oil, oil filter, and both fuel filters
    2005 mobius lsv 2900lbs ballast
    2005 mobius lsv
  6. #16
    Pensacola, FL
    Take at least $8K off of sticker, but you should be able to get up to $10K off.
    2008 Moomba Outback
  7. #17
    Aug 2008
    Hilliard, Ohio
    Quote Originally Posted by maxpower220 View Post
    I'm hoping for $10k most dealers are stuck at $7-$8k. Found one with $10k off per add but dealer baited and switched. If you know of a dealer giving $10k let me know.
    Now back to the oil change cost why with no change for the past 5 years in engine do they require a different brand of oil?
  8. #18
    Great prices, not that far of a drive to western ny.
    http://www.simmons-rockwell.com/chev...Model=Suburban
    http://www.simmons-rockwell.com/gmc/...cleModel=Yukon
    Pensacola, FL
    There have been some changes in oil to a different viscocity in order to reduce friction/drag and make the engine more effecient. Mostly in an effort to increase fuel economy in the overall scheme.
    2008 Moomba Outback
  10. #20
    1gal of Rotella T6 at Walmart 21 bucks.
    I buy 4 gallons, and filter is 18 bucks. So technically its 102. LOL But every 4th oil change its 80 bucks.
