Results 1 to 9 of 9
Thread: What is this on my gel coat?
09-11-2012, 06:41 PM #1
Look at this strange discoloration?!! I don't know what it is, its in several spots, all below the water line. Cant clean it off. IMG_5547.JPG
08 Outback. Private Lake Owner.
09-12-2012, 09:06 AM #2
That's normal. Just use The Works toilet bowl cleaner (other toilet bowl cleaners won't work) or if you want to get real intense, Muriatic Acid and water at about a 1:3 ratio or a little less. Wear gloves and safety glasses.
09-12-2012, 09:07 AM #3
If those don't work - wetsanding, rubbing compound, polishing compound, then wax will definitely do the trick.
09-12-2012, 09:54 AM #4
I used to use sno bol on my white hull. Nothing like it. Try not to breathe it though and rinse well. Wear rubber gloves or keep rinsing your hands too.
09-12-2012, 11:19 AM #5
Thanks, will that toilet bowl cleaner wreck my finish?
09-12-2012, 11:26 AM #6
I used Meguires marine cleaner wax on mine... Or If that doesn't work star brite hull cleaner which is muriatic acid I believe... the acid can bleach yr trailer if you aren't careful
2008 LSV 1100s 650IBS Reversible Pumps w\Timers
09-12-2012, 02:06 PM #7
No, it won't affect the finish, just be sure to hose it off and clean afterward
09-12-2012, 06:27 PM #8
When your rider has a huge wipeout that scares the ______ out of them, it is advisable to circle around once or twice, dousing them with a few nice rollers to wash off any residual _____ before you pull up and stop in the _____ to ask if they are ok and pick them up.
09-16-2012, 12:44 PM #9
uhh.. "the Works" Worked fine! does take a good ammout of elbow grease and time to get it off though.
