Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 165
Thread: Exiled...
  1. #51
    Feb 2008
    Traverse City, MI
    Quote Originally Posted by Brianinpdx View Post
    I gotta say, that green vinyl is a super cool color. Install is looking good Ian. Will be fun to see that boat on the water rocking loud. That's Chase's boat right?
    Yup, Chases boat.
    2013 Outback V
  2. #52
    Feb 2008
    Traverse City, MI
    Quote Originally Posted by bzubke1 View Post
    Do you happen to know the model number on those distribution blocks? I've been looking for a single input to a 4 output.
    I think the package is in the boat still, I'll have to get back to you on that one.
    2013 Outback V
  3. #53
    Feb 2008
    Traverse City, MI
    Ian is this the seletor you added to the ACR?
    David, I assume this 4 position would work 1, 2, 1+2 and off
    http://bluesea.com/products/6007 i believ this is what is installed with my 12 XLV with the pro mariner sport 20 charger.. i too would like the acr as i had the bepVSr in the old boat.
    hijack over continue exile install thread
    I didn't add a switch at all; front the factory it came with a 2 position switch, so I left it in.
    We don't charge with shore power, so I didn't see the need to change the switch.
    2013 Outback V
  4. #54
    Dallas, TX
    Post a schematic/drawing of how you see a conventional dual battery switch interfacing with an ACR/VSR. I'll look it over.
    Earmark Marine
  5. #55
    So David, is there a difference in the Perko 2 battery switch that came in my boat and the blue seas 2 battery switch? I think I want to add a ACR this winter when I redo my stereo install and want to know if I need to buy a new switch
  6. #56
    Earmark Marine
    This is copied but wanted to know if the switch would work with the acr in a very similar diagram or doe i buy a new blue seas switch
    Oct 2010
    Lake Wylie NC Area
    Jmotto,
    An ACR will work just fine when used in conjunction with a traditional 3-post 1/2/BOTH/OFF dual battery switch like the commonly used Perko brand or the Blue Sea 9001e.
    The real advantage to the Blue Sea OFF/ON/Combine 4-post dual circuit plus 5511 over the traditional switch, is when there is an on-board charger in the scheme.
  8. #58
    Oct 2010
    Lake Wylie NC Area
    If the upgrade includes a 2-bank on-board charger, then I would recommend going with the dual-circuit switch.
    With one action, you can combine and isolate the loads from their source battery. Since the dual-circuit has 4 post, rather then 3, the ACR is isolated from the batteries when the switch is off, allowing the charger to properly charge and condition the battery banks. With the traditional 3-post switch, the ACR will end up combining the banks when the charger is on. This makes the batteries one large bank.
  9. #59
    Dallas, TX
    David and Joe,
    The switch in the photo is a conventional dual battery switch.
    The dual circuit switch in the diagram is a 5511e.
    The conventional dual battery switch in the above photo cannot be introduced into the above diagram as is.
    So, post up a diagram of how you would wire a conventional dual battery switch in conjunction with an ACR/VSR.
    There are several methods but the results are different. Again, draw it out to see.
    Earmark Marine
  10. #60
    David and Joe,
    Earmark Marine
    I guess my question is this simple I think MLA answered it. No, get the combined switch
    Can I use this switch BS 6007 ( factory dual battery issue) with an ACR and Dual pro mariner 20 on board charger( factory installed option)?
