Page 11 of 17 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 165
Thread: Exiled...
  1. #101
    Feb 2008
    Traverse City, MI
    Ian,
    Did you lengthen the port accordingly after modifying the enclosure?
    The port didn't exist initially, lol. I actually previously had ~2.6ft^3, where the suggested is 2.2ft^3 with 14" long port. Cutting that corner off brings me to almost exactly 2.2ft^3, so I stuck with 14" in length, but its easy enough to play with, should the sound not be "right"
    2013 Outback V
  2. #102
    Feb 2008
    Traverse City, MI
    how about the sterring cable etc. i am interested on how you move the center hole conduit for wiring ballast and sterring cable
    here is my pic
    http://i258.photobucket.com/albums/h...IMAG0211-5.jpg
    I didn't have to move the hole, because the box is ~7" off the floor. The steering cable goes up and to the right of the enclosure, while the wires go under and to the left. The only thing that is giving me fits is what looks like a Cat5 cable that doesn't have a disconnect, I suspect it is for the radio remote but I have to track it down and untie it from the harness. Shouldn't be too hard, I just didn't invest any time into it.
    2013 Outback V
  3. #103
    so the front facade is sitting 7 inches off the floor. got it.
    got any pics of the back of that custom enclosure.
    Jun 2010
    Lake Houston
    Did you go all the way back to the battery for the power to the amps or did you go through the switch so you can select which battery the stereo gets run on?
    2013 LSV
    2005 LSV - SOLD
  5. #105
    Feb 2008
    Traverse City, MI
    The factory switch is not capable of switching between battery 1, 2, and off. I ran the power directly to battery 2.
    2013 Outback V
  6. #106
    Feb 2012
    St. Albert, Alberta, Canada
    Is the bed liner working good? How many coats are you up too? Is it the roll-on or the spray?
    2010 MOOMBA LSV
    340 CAT
    ACME 1235
    3100#'s
  7. #107
    Jun 2010
    Lake Houston
    What in the duece is the factory switch for then lol? I thought it had both positive battery terminals running to it, and it has one "output" terminal and depending on which battery you select (or both if you have it on 1+2), that would be the battery sending power to that "output" terminal. My thinking could be way off here, Im at work and boat is at home. Thanks for your replies.
    2013 LSV
    2005 LSV - SOLD
  8. #108
    Feb 2008
    Traverse City, MI
    This will be the first box I've done with just bedliner, so I'm not sure. It is the spray kind, and I've used 4 cans. The boat has ~35 hours on it and so far there has been absolutely no moisture in that area, so I'd imagine combined with the fact that its so far off the ground it won't be an issue.
    2013 Outback V
  9. #109
    Oct 2009
    Pacific NW USA
    Ian - 4 cans is plenty. The big help here is that you have elevated the base from the floor. This will eliminate moisture build up. In fact in my experience it doesn't need to be lifted up 7". Even 2-3" will improve moisture reduction. I would suggest to use birch plywood for the enclosure versus MDF as MDF tends to be like a sponge.
    -Brian
  10. #110
    Feb 2008
    Traverse City, MI
    7 is just where it ended up fitting the best around the wires through the floor and around the air box thing. Birch looks so nice too, one day maybe I'll stain a wood box instead of hiding it, lol.
    2013 Outback V
