Results 1 to 2 of 2
Thread: Light Bar wiring help
07-31-2005, 07:48 PM #1
I am going to attempt wire a 6 light bar, (home made) and I really dont know much about this sort of thing. I have an 04 Outback, it looks like there are 2 acc. switches that are not being used for anything. I think I might be able to pull this off but my main concern is, can I wire up all 6 lights, (55watts each) to one switch, or will that blow the breaker? I also need to find a connector to go through the hull that can handle all of the wiring, unless I can connect all of the lights together inside the light bar and just run 1 set of wires down the tower and use the vacant side of the connector that powers the tower navigation light. Thanks in advance for any help.
08-02-2005, 09:55 AM #2Junior Member
- Jan 2003
- Vancouver , BC Canada
- 18
Replying to Topic 'Light Bar wiring help'
You will need to use relays to switch all the power , the ACC switch on the dash will turn on the relays. Don't forget to use the correct size fuse. I would run more wire to allow you some flexability on which lights you want on. I use connectors made by Neutik sp? which work well and have 4 and 8 pin connectors. Check out www.diytowers.com for more info. Post pics when done ok
Seeking Flatwater
Trailer wiring
By tazz3069 in forum General ChatReplies: 10Last Post: 04-28-2008, 05:31 PM -
TOWER LIGHT WIRING
By drewdwn in forum General ChatReplies: 0Last Post: 12-31-2007, 06:25 PM -
Wiring diagram for 04 Mobius XLV
By noswes in forum Service & RepairReplies: 0Last Post: 02-06-2007, 11:07 PM -
Battery Wiring?
By radryan in forum Service & RepairReplies: 4Last Post: 02-26-2006, 11:24 PM -
wiring diagram
By iparky in forum General ChatReplies: 1Last Post: 12-07-2002, 11:58 PM
