Results 1 to 10 of 10
Thread: Fuel Economy
    May 2002
    Hickory, NC
    Default Fuel Economy
    Curious....What kind of GPH are you guys getting on your carbureated engines? Of course, depends ENTIRELY on how you're running your boats, but as a reference point, how about general cruising.....2000 to 2400 RPM is normal cruising speed.
    Chip
    Guest
    That is a good question, I have a 2002 Outback LS and seem to be running 4 to 5 gals an hour which seems high to me. If anyone has done some good tracking it would be very helpful information
    Jul 2002
    Northern California (Seba
    Default GPH
    I have a 2002 Outback LS and I am testing it and seem to be burning between 4.5 to 5 gals. an hour. I am very curious to what others are getting because this seems a little excessive. Let me know.
    Lake Bound
    Lake Bound
    2002 Moomba Outback LS
    Indmar, Carb
    Jul 2002
    Mechanicsville, va
    Default GPH
    I have a 2000 Kamberra and am burning about 4.8 gph with the 310 indmar while wakeboarding.
    Apr 2002
    Chattanooga, TN
    Default fuel economy
    I have a 2001 mobius v. Fuel consumption depends a great deal on the amount of weight in the boat. Wakeboarting with about 2000 lbs of water and 5 people we use about 6gph. With no ballast and cruising at 30 mph improves considerably.
    Jul 2002
    Orlando
    After reading these postings I decided to check what my fuel consumption was this weekend. I have a '01 Mobius and had the rear sac, 450 lbs of lead and 5 adults and 2 teen agers. Ran super unleaded in it and seemed to be about 5.25 gph. I will keep checking.
    Old Fogie Wakeboarder
    Guest
    My 2001 Boomerang with a four barrel Holley carburater and a K&N air filter now producing around 330 hp takes the whole 23 gallon tank in about 2 hours. Now that's gas consumption!!!!! But I get 0-36 in 3.3 sec and a top speed of 61 mph. Beat that!
    Guest
    Mar 2003
    Rockford, Michigan
    I have a 2001 Boomerang with an aftermarket four barrel Holley carburater and a K&N air filter now producing 330 hp and it goes through all 23 gallons in about two hours! Now that's fuel consumption!! But you know what I don't mind because now I have a top speed of 61 mph.
    Apr 2002
    Virginia and Colorado
    Default 61 MPH?
    JMO: What prop are you running to get 61mph?
    Does the K&N filter actually give you more power than the stock flame arrestor? I wouldn't think the flame arrestor is very restrictive. Plus, it's a worthwhile safety item.
    Bruce Vanderbilt
  1. Fuel Filter?? Lack of power on fuel throttle
    By slalomskier in forum Service & Repair
    Last Post: 08-02-2007, 04:52 AM
  2. replace fuel filter with fuel water separator
    By vansolo in forum Service & Repair
    Last Post: 05-04-2007, 01:17 AM
  3. Fuel Gauge
    By Gharvin in forum Service & Repair
    Last Post: 09-21-2006, 04:52 AM
  4. Fuel Tax Refund for Boat Fuel
    By Will Watters in forum Boat Owners
    Last Post: 05-03-2006, 02:14 AM
  5. Fuel
    By Bammer in forum Boat Owners
    Last Post: 11-26-2002, 09:57 PM
