Results 1 to 7 of 7
    Apr 2008
    California
    Default First outing sucked the big wazoo!
    So last weekend we finally get the boat out for our first outing of the year (long long story), anyway I launch and let it idle for a few then take off for the cove where we're camping. All is good as I watch the temp at around 110, a few seconds later it's suddenly at 240! I shut it down and let it cool and limp back later to the ramp. After cooling off I check the impellar and trans cooler, all good and clear?!
    After buttoning back up and checking everything including it's pulling water into the strainer, I floated it at the ramp and started it up and watched the temp gauge. It sat around 110 degrees for about ten minutes then suddenly shot straight to 240 again. I've come to the preliminary conclusion it's probably the thermostat or the block pump. Oh well, haven't had a chance to check either yet. This year has really sucked in more ways than one!
    Mar 2003
    Springfield Missouri
    I had my block pump fail last year and the temps were normal all the way to failure but it squealed like a pig for a long time. I would say it is something else.
    1998 Mobius
    310 HP PCM
    SOLD
    That sucks, Razz! Hope you can close the season out strong.
    Sep 2009
    newnan, GA
    More than likely the t stat stuck closed
    2005 mobius lsv 2900lbs ballast
    2005 mobius lsv
    Nov 2003
    Land O Lakes, Florida
    Hopeing for a speedy and cheap fix
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Sorry to hear about the late start and it getting cut short. Hope you're back out there quickly and cheaply.
    Henderson, NV
    sucks man.....
