Results 1 to 10 of 22
Thread: 06 obv running rough
08-15-2012, 09:02 AM #1Junior Member
- Oct 2011
- Cloquet, MN
- 15
I just traded my 02 outback dd for an 06 obv with 23 hours on it. It's like new but it has a rough idle and
Stalls on hole shot. I've tried carb cleaner and seafoam in the gas but problem persists. It looks like the
next step is changing the fuel filter, but I can't locate it? Any help or suggestions?2006 Outback V
310 Carb
08-15-2012, 09:30 AM #2
Mine is behind the fuel tank on the starboard side. Hope this helps
2005 mobius lsv 2900lbs ballast2005 mobius lsv
08-15-2012, 12:33 PM #3
Did you trade at a dealer? 30-60-90 day warranty? If you can't find the fuel filter I sure hope you had someone check over the boat, especially where you live where it tends to get very cold.
08-15-2012, 01:31 PM #4Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
I had a similar issue with my '06 OBV and ended up changing the "throttle mate". It's the small black box with a lever that the throttle cable connects to . It's back in the engine compartment. It was about $120 but that fixed the problem.
uh wait, you said you tried carb cleaner. Are you saying it carbeurated vs EFI? Mine was EFI.2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
08-15-2012, 02:13 PM #5Junior Member
- Oct 2011
- Cloquet, MN
- 15
Mine has a carb, I followed the fuel line on passenger side, but couldn't see it. I haven't taken the lockers apart yet
Though.2006 Outback V
310 Carb
08-22-2012, 08:21 PM #6Junior Member
- Oct 2011
- Cloquet, MN
- 15
Ok, I finally replaced the fuel filter, but it still stalls and idles rough? What do I do next?
2006 Outback V
310 Carb
08-22-2012, 09:33 PM #7Senior Member
- Aug 2011
- 2,522
[QUOTE=Young24;191695]Ok, I finally replaced the fuel filter, but it still stalls and idles rough? What do I do next?[/QUOTEc
Is the electric choke working?
I'd start with the basics, plugs, cap, rotor, wires. Since it only has 23 hours on it I'd bet it's been sitting with untreated fuel, you'll probably need to rebuild the carb, or at least disassemble it and clean the jets. You could try some stp fuel treatment, you might get lucky..http://www.instgram.com/jlyons30
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
08-22-2012, 09:42 PM #8Junior Member
- Oct 2011
- Cloquet, MN
- 15
I ran a tank with seafoam through it and it wasn't much better. How do you check the electric choke. I am planning on new plugs next.
2006 Outback V
310 Carb
08-22-2012, 10:03 PM #9Senior Member
- Aug 2011
- 2,522
If it's a holley carb, take the air cleaner off, there should be a metal flap covering two holes, see the ebay pic, it should be closed when cold, and after the engine warms up it should open. If you run the boat with a fake-a-lake or on the water it should open slowly and fully, what ever you do don't drop anything in there...
http://www.ebay.com/itm/1850-600-CFM...ht_1339wt_1180http://www.instgram.com/jlyons30
08-23-2012, 12:18 AM #10Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
why would SC make some 06 OBV's with carb and some with EFI. Mine was EFI. Was that an option back then?
2008 LSV - Gone
2013 other brand
