Results 21 to 30 of 31
    Quote Originally Posted by lsvboombox View Post
    Its a part inside the a60 actuator. If all is working properly there shouldnt be a clunk. I get no clunking while trailering. I can feel when the actuator extends after it has been compressed but i get no clunking.
    what does this "feel" like?
    Sep 2010
    Lake wallenpaupack PA
    It really feels like nothing. But i can tell when the actuator is all the way out. If i had to describe it i guess i would say a slight tug
    I can feel when my actuator extends all the way and then jerks the trailer along with it
  4. #24
    Sep 2010
    My setup is pretty smooth. If your trailer is clunking and jerking its either that shock or air in the system
  5. #25
    Oct 2005
    Durham, NC
    Yeah, mine is super smooth. I barely notice anything, other than the weight back there. I replaced the whole actuator assembly since I had multiple issues.
    Brian Roberts
    2001 Outback DD
  6. #26
    Aug 2007
    Alpine, Utah
    Brian, how did you bleed your system?
    Garn
    Garn
    2007 Mobius LS (Direct Drive)
  7. #27
    I always roll off the lone slow for a second till i feel the trailer pull. I dont hit the throttle like when theres no boat hooked up.
    The trailer gives a slight pull and light clunk noise as normal but i have been in a few trucks that a heavy jerk and clunk noise and thats bad.
  8. #28
    I used a mityvac...Easier to do with one person..
    2006 Moomba Mobius LSV
  9. #29
    Aug 2007
    Alpine, Utah
    Using the mityvac, do you suck it through the caliper or suck it through the master cylinder?
    Garn
  10. #30
    Quote Originally Posted by Garn View Post
    Depends on the mityvac, I think some can do both(push from the master), my cheapo one only pulls from the caliper which is all you really need...
