    Default 15W-40 diesel & marine s 15W-40 diesel
    So I was planning on changing my engine oil before the jam this weekend so I eased on over to Napa to pick up the usual 6 quarts of. 15W-40 AmsOil full sun diesel and marine engine oil. I found the 15W-40 AmsOil and went ahead and bought it up. Now that I'm at the lake house I'm looking at the new bottles compared to an old bottle and I realize that the new bottle does not say Marine any where on it. I get to looking closer and see that one is pretty much a diesel only application and the product codes are different.
    The diesel and marine is AME-QT and the diesel is DME-QT
    My question is is the diesel only oil safe to run??
    Jul 2009
    Fort Worth, TX
    As long as it has the correct certifications the manual specifies you will be fine. I run rotella 15w-40 which is pretty much a diesel motor oil with no problems.
    -2012 Supra Launch 21V
    -2008 Mobius LSV
    Sep 2009
    newnan, GA
    I run the same rotella in my boat and my tow rig no worries
    2005 mobius lsv
    Jan 2010
    North Texas
    I believe the CJ4 designation makes it ok.
    2006 Supra 20 - Sold
    2015 Supra SE450
    Feb 2009
    Wausau, WI
    I have run some different oils in my boat with no ill affects. Delvac 15w40, Rotella 15w40, Mobil 1 syn 15w50.
    But here is a link to a cummins forum that has some technical info between the two;
    http://www.cumminsforum.com/forum/am...me-vs-ame.html
    Maybe shoot them an email or call for specific answer.
    Matt
    Sep 2005
    Claytor Lake, VA
    From the owners manual
    Indmar recommends 15W-40 Pennzoil Marine in their
    engines. If not available, use a 15W40 motor oil with
    an A.P.I. classification rating of SL/SJ/CI4/CH4/CG4 or
    equivalent.
    2005 Mobius LSV
    Jan 2010
    Milwaukee, Wi
    ah, the good stuff. I run the one shown in the picture on the left. I'm sure you'll be just as good with the one on the right thou..
    08 Outback
    82 American Skier
