Results 1 to 7 of 7
08-08-2012, 07:49 PM #1
Depth Guage Puck - What kind of epoxy?
Seems like no matter what I try, my depth guage puck comes loose after about a month, and I no longer get a reading. I've tried some of the quick 5-minute epoxy a couple of times, and I've also tried Marine Goop, which I figured would work, but the same thing happened. Is there something else I should be using?
Or is it more likely that there's a hard layer of gunk in my v-drive compartment that the epoxy won't cure to? If that's the case, what do you guys use to clean the area before getting the puck to stick?'19 MAX
'13 Mobius LSV - Sold
'05 Mobius LSV - Sold
08-08-2012, 07:53 PM #2
Sand the area where the puck will be mounted, 60 grit should work, rough it up good. Clean with alcohol. I have had great luck with Heavy Duty Expoxy from Home Depot.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051Kraig - 2010 Outback V
08-09-2012, 11:47 AM #3
Interesting, as I have used silicone in the past to temporarily test a location and the puck has stayed there and never came up. Prep the surface is the trick including removing the oil film.
1998 Mobius
310 HP PCM
SOLD
08-09-2012, 01:13 PM #4
I have also used clear automotive silicone and on my 3rd year and have yet to have a problem with the puck coming up. Make sure to clean the surface good.
Patrick
5 light- light bar. 2015 RAM 3500HD Dually 6.7 Diesel w/ Aisin 6 speed tranny
Live life today!
08-09-2012, 04:31 PM #5
Thanks guys. I thought I was cleaning it pretty good, but have never tried sandpaper, so I'll give that a try, in addition to cleaning.
'19 MAX
08-10-2012, 11:09 AM #6Member
- Apr 2009
- Raleigh, NC
- 62
Make sure to test the spot before gluing!! I cleaned the surface really well (wiped off everything that came up, then degreaser, then alcohol) and then epoxied it down. Unfortunately, I didn't think much about the location and put it a little behind the raw water intake. Now, it rarely works. On the flipside - any ideas on getting it off?
05 Mobius LSV - gravity 3 ballast and wake plate
single axle trailer
DIY hot water shower installed
DIY tube inflator installed
08-10-2012, 11:31 AM #7
Bite the bullet and buy another puck. I would not recommend removing the 1st one.
2018 Max with a little extra weight here and there
