Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
Thread: Mmandley
  1. #31
    Nov 2003
    Land O Lakes, Florida
    Mike, the IBS, how full do you think it gets? I know they say its 650lbs but the bow area is fairly shallow under the seat.
    I am thinking about 2 smaller bags linked together would effectivily do the same thing and would still have access to under the front center seat for storage of a small anchor.
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  2. #32
    I get mine 100% full and put the anchor (which is rarely used) behind the leg on the starboard side.
  3. #33
    You can go with 2 smaller bags of you like. I think it will work just fine just a bit more plumbing to run.
    Mine is designed for the moomba bow and when its full the cusions will pop up a little, i drain it slightly to stop that. I have room on both sides at the end of the legs, for helmets and the anchor.
    I know when i fill my front ballast and not the rear i ride really low on the nose, only time we run it like this is for Wake Boarding.
  4. #34
    Nov 2003
    but, your Mojo has a bigger bow that the LSV. Do you remember are the seats bases now higher on the 13 LSV compared to the 08 LSV
    I'll get the IBS if its worth it, but if it only fills 1/2 to 3/4 then its not worth getting, I'll go a different route
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  5. #35
    I think the seat bases are higher, but can't remember exactly. I like you're idea, too.
  6. #36
    Aug 2008
    Cottage Grove, MN
    I can get my IBS at roughly 75-80% just guessing. It pops the front seat up and I drain a bit to get the seats back down.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
  7. #37
    Sep 2010
    Lake wallenpaupack PA
    I can get my ibs full but it also pops my cushions and my cup holders. When i hear the cup holders jingling on the floor i know the ibs is full
  8. #38
    If you split using two bags, one on each side, you can daisy chain for filling -- that's the easy part. Emptying will be a bit harder. I'd be tempted to empty from each bag. A little more plumbing.
    Might not be the case with the reversible pumps & check valves installed. The 1,100 & 370 I have linked together can be drawn empty. Both legs of the IBS also drain completely.
    Might be time for an upgrade for you, too!
  10. #40
    I always wait at least 2 years after Stacy. Not yet.
