Thread: Engine running rich
07-20-2005, 02:22 PM #1Junior Member
- Jul 2005
- 1
Engine running rich
I have a 98' Moomba Mobius, port injected 5.7 L engine, 320 HP. Problem is gas coming out the exhaust, but engine runs fine. Changed the thrmostat, and spark plugs but still runs rich.
08-25-2005, 08:11 PM #2Junior Member
- May 2005
- 7
Replying to Topic 'Engine running rich'
dodes
Did you get this fixed? I have a similar problem with an '01. Wanted to see if you had any luck and what the problem was.
08-26-2005, 06:51 AM #3
Cold start valve not opening all the way after engine is warmed up?.........Any fuel system cleaner used recently?..........
08-26-2005, 11:03 AM #4Brian Raymond Guest
Does your motor have the watercooled fuel pump canister mounted on the front starboard side of the motor? Is there raw fuel coming out of the stbd. exhaust? If yes, you may have issues inside of the canister. If there is corrosion or the canister not winterized properly, fuel will mix with the water and go from the pump out of the cooling line to the stbd. manifold and then exits the boat. Water does not mix with the gas because it is pressurized. Hope this helps, keep us posted. Brian Raymond
'01 Running Rich/ O2 SENSOR?
By wforic in forum Service & RepairReplies: 1Last Post: 08-26-2005, 03:05 PM -
'01 Mobius running bad
By wforic in forum Service & RepairReplies: 1Last Post: 06-05-2005, 10:47 AM -
Running Hot
By wdf in forum Service & RepairReplies: 1Last Post: 06-26-2003, 10:08 PM -
engine running poorly
By lickmychode in forum Service & RepairReplies: 14Last Post: 06-17-2003, 10:40 PM -
Carbureated Engine Not Running Right
By ChipB in forum Boat OwnersReplies: 9Last Post: 03-01-2003, 10:59 AM
