Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
  1. #51
    Feb 2011
    Dallas, TX
    What were you guys using to shim the mount to the tower? I bolted mine on and when I put my boards on, had issues with the mount swiveling around.
    2009 LSV Liquid Force Edition
    - Gravity III
    - Z5 Rack
    - ACME 1847
    - Polk MM6501UM - Kicker IX500.4
    - Kicker CompVX 12" - Kicker IX1000.1
    - Pair Wetsounds Rev 10s - JL Audio HD750/1
    - RGB LEDs
  2. #52
    Lake Amistad, TX
    Quote Originally Posted by Clamcakes View Post
    Any little piece of rubber, cut in small strips, lay it inside the bracket, then crank down on it till she's good and tight!
    http://www.homedepot.com/p/DBHL-1-1-...0#.UYfEnMpu7nc
    not this particular one, but just so you get an idea... any rubber coupling will do then you cut it what ever size you need
    2008 LSV Blue on White
  3. #53
    Aug 2011
    Default Re: Rotating Board Rack Suggestions for XLV
    I cut this down and wrapped it around...
    http://www.menards.com/main/mobile/f...585-c-6613.htm
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
  4. #54
    Feb 2011
    Dallas, TX
    thanks...going to make a run to home depot today. Parrot I like what you did with the AC tubing for the surfboard rack. Noticed when I put a wakeboard in there, issues with it sliding around and slapping on the bottom board.
    - Gravity III
    - Z5 Rack
    - ACME 1847
    - RGB LEDs
  5. #55
    Aug 2011
    Wolfman or someone in this thread mentioned it, pool noodles...
    Not sure what type of wake boards or surf boards monster design engineers use but the wake board rack is too small and the surf rack is too big.
    For $125? I can deal with it...
  6. #56
    Feb 2011
    Dallas, TX
    where the heck did you find a black or gray pool noodle!?? Only pool noodles I see are neon colors, blue, green, pink etc. I'm thinking some AC insulation like this would work on those forks.
    http://www.homedepot.com/catalog/pro...17a041_300.jpg
    And yeah at $125 a pop I can deal with it too. I wish I could mount the racks higher like moombadaze, but the combination of my Z5 rack and Rev 10s wont allow it.
    - Gravity III
    - Z5 Rack
    - ACME 1847
    - RGB LEDs
  7. #57
    Yep - that would work too. Look for the pipe insulation in about a 1/2" or so. I'd look for the uncut or unspliced so it will just slip over and you won't have to deal with any sticky mating edges.
    I found different thicknesses of pool noodles too. Wally World, Target, etc. Mine HAD to be yellow though
  8. #58
    Aug 2011
    Pipe insulation at Menard's..
  9. #59
    Jul 2009
    Spokane, WA
    Are the stock forks a Monster product, or did those come from another company? The forks on these Monster racks look very similar, not to mention they are sized for the elongated oval bar that are on the stock towers (the somewhat newer stock towers that is).
    2015 Supra SC400
    08 LSV - Sold
    Go big, or go home.
  10. #60
    Aug 2011
    I noticed today the color is starting to fade on my racks... They still work great and still a great deal for the $$$...
