Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Sep 2009
    newnan, GA
    Default What head unit are you using?
    What wired control compatible head unit are you guys using?
    2005 mobius lsv
    Commerce Lake, MI
    I'm using the Kenwood KMR-550U I'm still using the factory Aeware controller at the helm and added a second Kenwood KCA-RC60MR on the transom. You can also use the digital KCA-RC55MR but I didn't see the need to spend that much money on one.
    2017 Moomba Craz
    Sep 2009
    newnan, GA
    I swapped to a Sony unit sometime ago and haven't been able to use my controller since. I also have a transom remote that I need to wire in been sitting on a shelf for a year
    2005 mobius lsv
    Lake Point UT....
    swapped it all out for the kenwood kmr700u. it's an awesome hu if all you use are radio/xm/ipod/usb. it has no cd drive and is NOT compatible with the older remotes..
    couple of threads on here from guys that went to this hu and I think the general consensus is very favorable. ebay has it cheap..
    Sep 2009
    newnan, GA
    Looks like the 700 would require some dash modifications as well looks to larger than a single din
    2005 mobius lsv
    Feb 2010
    Canton, Ga / Lake Lanier
    I am using the Kenwood 550U with 2 of the KMR107 digital remotes.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Feb 2010
    Quote Originally Posted by ga-lsv05 View Post
    From what I understand it is not. Only the face is larger. The part that actually slides in is a single DIN.
    Tow Rig:
    Sep 2009
    newnan, GA
    Oh ok. Probably gonna go with the 550
    As I'm not sure how much longer I will own this boat
    2005 mobius lsv
    Save your $$.
    The 2013 Moombas come with Sony HU's.
    Sep 2009
    newnan, GA
    Save your $$.
    I want the new owner of my boat to be able to use the remotes
    2005 mobius lsv
