Results 11 to 20 of 27
    Aug 2006
    Millington TN
    So is running at 3500-4000 for sustained periods of time bad??
    Running at that RPM for extended times should not be an issue as long as the engine is able to operate within the designated RPM range at wide open throttle.
    Larry Engelbert
    Indmar Marine Engines
    "Power to the Sport"
    Aug 2015
    Spokane, WA
    Quick question: I have a 2008 Moomba LSV with the 325 assault MPI (top spark arrestor) with the factory OJ "wakeboard" prop I was turning 5200-5500 at WOT and the rev limiter never once kicked in. Wouldn't this suggest the 5200 - 5500 RPMs is with the engines specified RPM range? No engine modifications or tunning have ever been done to the engine. Thanks.
    Aug 2015
    Spokane, WA
    I forgot to add; I have since swapped props to the acme 1847: No Ballast, WOT I'm at 4600 RPMs / 38 mph (gps). Fully loaded with 1900#'s of ballast I'm at 3000 RPMs wake surfing @ 11-11.5 mph. The only time I've run WOT is to test the old prop and the new prop. I'd be interested to see where the new prop lands full ballast WOT. But can't imagine repropping again for scenario I would never put my engine through?
    How will propping the boat for full ballast, WOT RPM impact the RPM range at wakes surfing speeds?
    Thanks again for your help!!
    May 2013
    Quote Originally Posted by Jeepers View Post
    This is what I'm wondering. You say to load the boat up with all the people and ballast I'd ever do and then test WOT. The only times I've ever gone and ever will go WOT is with empty ballast. And I've never seen my engine get even remotely close to hot. Our water temps rarely get over the low 70's so that's often a 20+ degree decrease from what our friends in the South see.
    Also, it'd be a little tricky to fill EVERYTHING and then try WOT, because I have probably 650 pounds of ballast that's exclusive to the Port side and not the starboard. I suppose I could compensate by having more people Starboard if I was to test. But I'd be ill advised to try to go WOT in a unevenly weighted boat.
    www.TraysonsToybox.com
    Portland Oregon
    I have to go wot just to get to surf speed loaded lol
    -Jake
    Lol are you kidding?
    I just ease into the throttle and up she goes.
    Wake boarding I give a little more but not wait until rider is out of the water lol
    [COLOR="#696969"]
    May 2013
    Spokane, WA
    Default Don't Kill Your Engine!
    I put the hammer down loaded. Gets the surfer right up and off we go.
    2013 LSV Red/White
    1100lb upgrades in each rear locker!
    Stock 500 Bow ballast
    650IBS
    Manual Flow equipped
    Boards
    Hyperlite Hi-Fi "The Illest"
    CWB AMG Carbon
    Phase 5 Razz
    Byerly Volt
    4.6 Ronix Koal Fish
    Phase Five Scamp (kiddos)
    Quote Originally Posted by icemanftr View Post
    I drop the hammer too but it's not everything she has lol
    Every time that happens they lose the rope or get pulled over the board
    [COLOR="#696969"]
    never had the need to drop the hammer when full surf ballast was full, that 345 "Surf" motor with the 1235 prop was a wicked package. Just roll the throttle on and everyone would be right up.
    May 2013
    Spokane, WA
    Oh I don't have to, I just love coming out of the water like a raped ape.
    2013 LSV Red/White
    650IBS
    Boards
    CWB AMG Carbon
    Phase 5 Razz
    Byerly Volt
    4.6 Ronix Koal Fish
