Results 1 to 10 of 17
Thread: Exquisite vinyl cleaner
07-09-2012, 03:25 PM #1
I've used this stuff extensively for about 4 or 5 years now, and have been really pleased with it. I know quite a few people use it here, and wanted to share what I consider a good deal. I'm in no way or function associated with this company - I just know I've been fortunate enough to get in on some good deals from this board and wanted to pass it on in case anyone uses it.
Basically you buy one of the concentrated quarts (makes a gallon) for 29.25, and you can get up to 2 or 3 more at 14.95. Shipping is included. When I went to buy it through ebay, it didn't ring up properly so I emailed them and they sent me an invoice via paypal at the correct discounted price.
Again, not trying to push this on anyone just wanted to throw it out there.
http://www.ebay.com/itm/Exquisite-Bo...06%26rk%3D1%26Current: 2010 LSV
Previous: 2007 Outback
07-09-2012, 03:28 PM #2
how well does it clean up the vinyl..my white is starting to turn to a darker white and i want to bring the color back
Rockford fasgate cabins
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
Polk P330 amp (subs)
07-09-2012, 03:32 PM #3
It cleans as good as any other I've tried. This weekend we added a scrub brush to the cleaning routine (we normally clean after every use with exquisite and towel and then once a month we do a deep scrub) and you can really tell how dirty your vinyl is once you scrub it.
Current: 2010 LSV
07-09-2012, 03:59 PM #4
nice..yesterday i threw some zep heavy traffic carpet cleaner on my carpets ,power washed them then shop vac'd the carpets dry..made them look brand new
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
07-09-2012, 05:33 PM #5
^^Now that's what I really need to do. My 2 going on 3 year old carpet is looking pretty worn. So do you just spray it on, let it sit, then spray it off? Or do you need to scrub too?
Current: 2010 LSV
07-09-2012, 05:44 PM #6
I like exquisite a lot too. Thanks for posting up the deal! It's strong enough to clean very well, especially with a brush, but not as harsh as Malco. I still like Malco for the deep cleans though. 303 cleaner for the more frequent cleanings.
Regardless of cleaning product you should always use a wet microfiber to rinse the vinyl after you clean it. You will be amazed how dirty the water will get, especially considering the vinyl is "clean". It will stay cleaner longer as well because there is no detergent residue on the seats.
07-09-2012, 06:15 PM #7
i sprayed the zep all over the carpet and then i pulled out my john deere power washer, fired her up an put the biggest degree nossle on the end ( so you have a less likely chance of ripping the carpet) and power wash away..then i pulled out my shop vac with the wide floor acc. piece and sucked all the water out of the carpet
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
07-09-2012, 08:37 PM #8
I'll be doin this on Friday since I am sure my carpet is going to be stinky from putting the boat away soaking wet a month ago
Sent from my iPhone newtys droid killer using TapatalkDavid
07-09-2012, 09:10 PM #9Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
If you have a mist spray bottle, try using some fabric softner on the wet carpet after you rinse it. It will add a scent (unless you buy unscented) and it will keep the carpet from getting crispy when it dries.
Power wash from the edges to the drain and do it until the water is clean. It will take a few passes on the heavy traffic areas. Don't forget to pull the filter on the wet/dry vac. Unless you like soggy, smelly filters that fall apart.1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
07-09-2012, 10:06 PM #10
i took my filter off so it all just dumps into the can and then i just empty the water out in the grass..so im watering the grass and cleaning the boat..win win haha
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
