Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Nope, mine I had a hard time getting them all the way in. My wrists hurt after a while hen I did my GiV upgrade ith all the fittings.
    Jul 2013
    Whiteshell, MB
    Once i used the pliers it wouldn't tighten, so i left it. Tested about 40% fill and no leak. Hope to get out again tomorrow and fill it full. I bought the cement just in case.
    Thanks,
    2012 Mojo2.5
    Ballast:
    1100 surf side
    400 goofy side
    500 under floor
    725 IBS
    260 bow floor
    (The more spotters the better)
    Acme1235
  3. #23
    Jul 2013
    Whiteshell, MB
    Popped off today. I will be using the PVC cement tomorrow. Any concerns about the bilge filling up / components getting wet or flooded?
    2012 Mojo2.5
    Ballast:
    1100 surf side
    400 goofy side
    500 under floor
    725 IBS
    260 bow floor
    Acme1235
  4. #24
    Oct 2010
    Lake Wylie NC Area
    if the correct threaded fitting(s) is popping out of a threaded sac port, the threads on one or the other is damaged and glue will likely not hold.
  5. #25
    Jul 2013
    Whiteshell, MB
    That does concern me.... The threads weren't too bad and i noticed Boonejeepin had the same issue. I know they are boat engines / components but i just worry about water splashing around in there....
    2012 Mojo2.5
    Ballast:
    1100 surf side
    400 goofy side
    500 under floor
    725 IBS
    260 bow floor
    Acme1235
