Results 11 to 20 of 25
  1. #11
    Heat from a hair dryer for 10-15 min, then pop them out. Wakemakers has a great video on their site.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  2. #12
    Jul 2011
    Murrieta, CA
    My bags were not glued from the factory. I think the heat from the engine was heating the fitting on the v drive bags and they would pop out to the bags after an hour or so on the water.
    Then I glued them and have had no problems since.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  3. #13
    May 2010
    Muskoka, Ontario
    Quote Originally Posted by Boonejeepin View Post
    Are you talking about the threaded adapter popping out from the bag or the quick release fitting from Fly High with the little red clips?
  4. #14
    Jul 2011
    Murrieta, CA
    The plastic threaded adapter was popping out from the bag's threaded insert. After a couple of times the threads were marred a bit and seemed to pop even more often.
    A small amount of PVC cement and the fittings have never popped out again.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
  5. #15
    May 2010
    Muskoka, Ontario
    I wonder if its a design flaw on Fly Highs part, since a threaded coupling should never be able to pop straight out, unscrew is a different issue.
  6. #16
    you actually "pop" out the ones that are glued in from the factory ofter you heat them up a bit with a hair dryer.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  7. #17
    May 2010
    Muskoka, Ontario
    Hmmm one would think that would ruin the threads on the bags? No?
  8. #18
    only when one makes the mistake of using a heat gun instead of a hair dryer and leaves it pointed at the bag until their daughter asks, "Is it supposed to be smoking?"
    BTW - I have a factory bag for sale. CHEAP!
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  9. #19
    Quote Originally Posted by loudsubz View Post
    Nope threads are fine if the directions are followed
    Jul 2013
    Whiteshell, MB
    Reviving this older thread.... I got my bag inserts today ( I chose not to try and remove the ones from the factory bags until I had spares). I started off just trying to thread them in, then went to the tape. I read somewhere here that o-ring seal is a good idea. I didn't have that but the tsunami pump connection that came with the sacs had some grease on there rings so I applied a bit of that to the o ring and screwed it in. Now here is the weird part.... I tightened the bottom valve but it turns indefinately ( like its stripped) but I don't feel it resetting as I would expect. I filled the bag with air and tested with soapy water (no bubbles = no leaks). I am waiting for the weather to clear up so I can really test them but it just seems odd to me that I can keep turning this by hand...
    Anyone experience this? Any ideas?
    Thanks,
    2012 Mojo2.5
    Ballast:
    1100 surf side
    400 goofy side
    500 under floor
    725 IBS
    260 bow floor
    (The more spotters the better)
    Acme1235
