Results 1 to 3 of 3
Thread: ballast switch
06-23-2012, 10:42 PM #1Junior Member
- Jan 2007
- 25
ballast switch
on my 07 moomba lsv the front bag fill switch will not activate the fill pump pump works with the two rear bag switches replaced the switch still same issue any ideas?
06-24-2012, 01:13 PM #2Junior Member
- Aug 2011
- 6
Check the fuse under the dash. I think it is way up under there. Should be a small 6 gang fuse block above the steering cable. It protects the drain pumps and relay circuits for the fill pump and valves.
06-24-2012, 07:31 PM #3Junior Member
- Jan 2007
- 25
Haha feel prety dumb now that did the trick I looked right over that fuse block and wrote it off as the switch was still getting power guess thats what I get thank you for the help
