Results 1 to 8 of 8
    Default Mojo factory front speakers only getting bass
    My daughters clued me in this morning that the bow speakers weren't working. I figured one of them had messed with the fader. Adjusted to center but best I got was a little bass.
    Looks like all speakers run thru amp. Top 4 in the pic are marked for the bow.
    Any ideas?
    Feb 2010
    Canton, Ga / Lake Lanier
    Time for some Wetsounds!
    Check the crossover maybe it got switched to low pass...would be strange for just the tweeters to go out.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Oh man, Im dying for my wetsounds system. But, that new fridge & dishwasher ate up some of my stereo funds.
    Aug 2006
    C'mon drew spend now. Save later. Kids won't mind.
    Brad
    Mississippi/Louisiana
    2011 Launch 21V
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Oct 2010
    Lake Wylie NC Area
    First thing I would do is inspect the amp settings to make sure that the cross-over filter for the bow speakers, which I would think would be "Amp-1", is not set to low-pass. Its odd to have two speakers with no highs (inop tweeter) on the same half of the amp. Could be both tweeters or could be amp. You could swap one of the bow speakers with one thats working normally and see if the highs are still missing, as well at what the known good speaker sounds like plugged up to where the bow was. At this point, you've pretty much narrowed it down and can let the dealer know what it needs.
    Swap the rcas and see if the "bass only" moves to the cabins. Then it's your amp setting, if not , you got two blown tweeters.
    Thanks everyone! Heading down to the boat now to try and figure it out and install my ballast upgrade.
    That was it! One little switch on the side of the amp that I couldn't see until I crawled in there. Thanks again for the assistance!
