Results 1 to 2 of 2
Thread: transmission oil in bilge water
06-20-2012, 07:25 AM #1Junior Member
- Nov 2005
- 1
i own a 96 outback and cannot diagnose the source of the leak. it is not much but it is fowling the bilge pump and i do not want to contaminate the lake.
06-20-2012, 10:56 AM #2Banned
- Oct 2005
- Durham, NC
- 649
One thing to check. There is a plate on the bottom of the transmission held on by two bolts. Behind this plate is the transmission screen filter. If this plate is not installed perfectly, it can develop a leak. Also, there may be a gasket there that has deteriorated to the point of leaking. It is very difficult to get to. While you are in there, I suggest you clean the filter.
