View Poll Results: What speakers are you "Rockin"?
Voters
59. You may not vote on this poll
  • Factory
    9 15.25%
  • Exile
    19 32.20%
  • Wetsounds
    9 15.25%
  • Kicker
    11 18.64%
  • Polk
    10 16.95%
  • Krypt
    1 1.69%
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
  1. #21
    Sep 2010
    Dallas, TX
    There was no choice button for Krypt and Kicker?? lol
    NEW!
    ZX1000.1 sub amp/Kicker L7 sub
    ZX380.4 Interior/Kicker 6.5's
    2-G1300 JL Amps/Krypt HLCD's
    Krypt 4200/XM Satellite/No Head unit anymore
    89' Comp Resto:
    http://supraboats.com/bbs/showthread.php?t=8193
    Riding and Mod pic's:
    http://www.supraboats.com/bbs/album.php?albumid=86
    89' Supra/Custom Tower & Interior/Swivel Racks
    4 Blade-14X14/1600 lbs Ballast
    Roswell Bar/Led's/Krypt 6.5 HLCD's/Krypt 4200 Eq
    JL-PPI Amps 1750 Watts/Kicker Interiors/L7 Kicker Sub
  2. #22
    Jun 2011
    augusta, GA
    Wetsounds in-boat & tower, Arc Audio amps, JL Sub
    91 Supra Sunsport
  3. #23
    Arc makes wet sounds amps. So same thing.. Nice setup.
    May 2012
    4 kicker ks 65's on tower powered by a 200.2 amp, sound is ok, but not that great. I had to kill all bass to them so the rider can hear. Inside of boat is factory 6 kicker system. Anybody have any ideas—or experience—adding a sub? Trying to find a solution around the 4-500$ mark.
  5. #25
    Jan 2010
    North Texas
    Give this a peek, brand new from Wetsounds
    http://www.facebook.com/photo.php?fb...type=1&theater
    "AS-10 Subwoofer System! All in one powered subwoofer. High Power 500 watt high efficiency amplifier built into fully sealed compact fiberglass enclosure with high output Wet Sounds 10 inch subwoofer. Small Size L x W x H (IN) 11.5” x 14.5” x 12.75” A True plug and play subwoofer system for just about any application you can think of. In your boat, in your car, in your ATV. Endless options. Now Shipping. $549 msrp."
    2006 Supra 20 - Sold
    2015 Supra SE450
  6. #26
    dusty beat me to it!
    along with a suggestion to search the audio section of the forum. it's full of ideas!
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  7. #27
    Jul 2009
    Cleveland, Tn
    Rockin' the factory inboats/roswell tower speakers, and 12' subwoofer with 2 Kicker amps.
    New boat this year, new sound system next spring or this winter if I can get it ok'd by the boss! Going all Exile or all Wetsounds. Still can't make up my mind but I got time!
    2012 Mojo
    2009 LS (SOLD!!!)
    2010 Tundra 5.7 Crewmax 4X4
  8. #28
    Jul 2009
    Fort Worth, TX
    Interior-Polk mm651 powered by a JL 360/4.
    Tower-Rev 10's powered by a wetsounds syn 4.
    Sub- Wetsounds xs-12 powered by a Alpine mrp-m500.
    I'm waiting for the new wetsounds sinister amps to come out, and most likely going to get a rev 410 to go in between the two rev 10's. Then use the syn 4 for the interior speakers. The specs on these sinister amps look rediculous.
    SD6:
    Stereo @ 4 ohms 6 x 185 Watts
    Stereo @ 2 ohms 6 x 290 Watts
    Bridged @ 4 ohms 3 x 585 Watts
    SD4:
    Stereo @ 4 ohms 4 x 185 Watts
    Stereo @ 2 ohms 4 x 340 Watts
    Bridged @ 4 ohms 2 x 685 Watts
    SD2:
    Stereo @ 4 ohms 2 x 400 Watts
    Stereo @ 2 ohms 2 x 620 Watts
    Bridged @ 4 ohms 1 x 1250 Watts
    -2012 Supra Launch 21V
    -2008 Mobius LSV
  9. #29
    Apr 2010
    Austin, TX
    Jmvotto, just wanted to clear it up, Arc does not make our amps. We both share the same build house and engineering team on the SYN amps as they do on their KS line. That platform is so robust and efficient and cool running, it made sense to base the SYN off that existing platform. So similar platform but we have higher power on some models with parts change and conformal coated boards for true marine, stainless steel shroud vs steel, aluminum end panels instead of steel, syn-6 is 100% unique on the crossover input stage etc..There are so many instances that you will see similar amps on the market across many brands with them sharing a platform but some having different parts and functions, but the companies share the same build house. I could point out a couple right now that are exactly the same
    And sometimes you will see 100% proprietary amps.
    The new HT amps are 100% ground up Wet Sounds design and the insane Sinister are 100% ground up Wet Sounds design. We have had the time to design and develop these platforms from scratch, been working on these for 3 years now. We are keeping the SYN amps in the line so we have 3 series of amps, HT, SYN and Sinister. HT amps are full range class d at a great price point with high power and small size and the Sinister amps are full range class D with some of the highest power to size ever put into a 12 volt amplifier. The AS-10 sub above uses a radical direct amp technology that produces crazy amounts of power with very little current draw. The amp module built into the AS-10 sub is enclosed in a plastic module. You have to see and hear this sub to believe it. It pounds!
    Bzubke1, Yes the sinister amps are just ridiculous. Wait to you see the size. 13 x9. With almost 1800 watts on the 6 ch. All sealed with no fan. The transformer has a patent pending design developed just for this amp. over 80% efficiency at full rated power. This is unheard of in a 12 volt amplifier.
    Tim
    Wet Sounds
  10. #30
    Jul 2009
    Fort Worth, TX
    When are the sinister amps going to be available?
    -2008 Mobius LSV
