Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Aug 2010
    Acworth, GA
    Ah perfectly understandable. Fried noggins must be properly cooled and cared for
    Kraig - 2010 Outback V
  2. #12
    Captn Kraig, you know the drill on mods.. pics or it never happened...LOL
    Aug 2010
    Acworth, GA
    Roger that. I'll snap a few of the devastation tonight. We are going to go out on the boat tonight, no boarding, just a ride and swimming, which is good as I have no ballast sysytem currently LOL. Oh, good reminder, I need to shut off the valves to my thru hulls for the ballast before launching! Bluub Bluub Bluub... boat's sitting awfully low in the water ain't it LOL
  4. #14
    Aug 2010
    Acworth, GA
    Still waiting on parts from WakeMakers, should be here Monday, until then no ballast.
    Here is the port locker with divider wall and ballast pumps & mounting board removed and the port ballast fill/drain line run over to the starboard locker
    This one is the Starboard locker with all of the lines pulled into it
    This shows two water lines and the two power lines above the valve that I redirected to starboard rather than run them behind the muffler at the transom
    This one shows how there isn't really any room between the muffler and transom
  5. #15
    Aug 2010
    Acworth, GA
    Making progess. Need to modify the pump & locker divider wall, basically reverse the panel & mounts but it doesn't quite fit the starboard locker so tear off existing carpet, trim to size, notch bottom for starboard side ballast fill/drain.
    I also need to order some OEM carpet , about 2 by 6 feet is all to wrap divider wall once reveresed & trimmed and then to glue to the port side transom where I have a non OEM piece of carpet stuck back there for now.
