Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
    Jun 2009
    Victoria BC Canada
    Default EQ Install Advice
    Anyone have some pictures of how they installed their EQ or ZLD under their dash? I've been searching the forums and found one post but the link it refers to has been removed.
    Thanks in advance!
    Wade
    2007 Outback V
    Wade, on the obv I put two l brackets on the steering column bolts then added some lock washers an nutsthen screwed some plastics board a tad bigger than the eq to the brackets. Then just mounted the eq to the board flush to the board. Its only place I could find to mount on the obv, not enough dash board anywhere else.
    Check out my profile pics.
    Joe
    Apr 2011
    NY
    Wade - I ran into a similar problem this spring. I followed JM's instructions as indicated above. Worked great. All you need is a couple L brackets from Lowes, nuts, washers, and a "board" cut so size. I thought I would have some starboard left over from my amp rack but unf. I didn't. I went to Target and picked up one of these and cut to size: http://www.target.com/p/superboard-p...4x17/-/A-85899
    '13 Mojo
    I mounted mine below the throttle by the gravity III switches. With a trim piece from a stereo place, it looks pretty clean and its at your finger tips for volume control.
    2016 Craz Surf Edition
    Upgraded to 1100's in the rear
    Wetsounds Rev 10s with SYN DX 4 amp
    Muskoka, Ontario
    I just ended up doing my krypt eq this past weekend.
    Did what was suggested above. Cut a piece of 1/2 inch plywood just slightly wider than eq, bolted it below the oem switch panel on right side with 2 L brackets, mounted eq to board and also attached a piece of wire to the board near the rear to stop any movement up and down on big waves etc, it's solid.
    here is the pic
    Tried to PM you, says your full mang =(
    Muskoka, Ontario
    that looks good! on our 2010 i dont think i have the room under the switches to do that though
    Quote Originally Posted by loudsubz View Post
    You have to buy a blank and move the switches up. i have a blank i was trying to contact Brain for any tips before i break out the dremmel. I will take some pics and do a write up if i can get this done LOL.
