Results 1 to 10 of 17
Thread: Bilge float switch stuck
07-07-2005, 09:48 PM #1
Right out of storage this spring the bilge pump on my 99 Mobius quit working. With some help from Brian R. and my local maint. guy I got it running by simply removing the cartridge and spinning the vane manually (it gave a 'click' and then started spinning freely again)
Now the other shoe - the float switch appears to be stuck. The bilge is running all the time even when no water is there to pump. I tried rapping on it with a wrench but no luck. Right now I am stuck with disconnecting the battery when I am not using it.
I have recently started manually draining from the drain plug to get more water out. Could this have left the switch dry? and caused it to hang up?
Any ideas - or just replace the whole assembly. What about flooding the switch with the power off to encourage the switch to free up?
All ideas welcome.
I know a bilge/float assembly is not that expensive, but it does not look like it is that easy to get out because there is a bulkhead very close to it.
TIA
DaveIf you believe something to be true, it will be - in it's consequences.
07-07-2005, 10:22 PM #2Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Replying to Topic 'Bilge float switch stuck'
Run a hose to it and wash it out.
Typically they twist and come off the floor, base plate stays attached to boat. I do not know if this works with SC but it does with my duck boat so I can clean the gunk out.
Worth a shot.
SD2Naked red and white 2005 Moomba LSV
07-08-2005, 12:54 AM #3
I can get the pump cartridge out, but the float switch is a separate assembly. It seems to be pretty secure to the floor. The pump is working fine now, but the float switch is always on.
Thxx
07-08-2005, 08:21 AM #4Senior Member
- Mar 2004
- Wylie, Tx.
- 212
My bilge did the same thing. Then I had to just turn it on by the switch on the dash, which wasn't too bad as long as I was there to do it. I replaced the whole thing, pump and float switch, for about 30.00. Walmart carries the Attwood line. Snipped a couple of wires, covered those with liquid electricians tape and screwed it back to the floor. Hardest thing about it was getting to it and the limited room you have to work with.
MedicMedic151
06 Mobius XLV
07-08-2005, 09:46 AM #5Guest
Try using compressed air and see if you can dislodge anything that may be stuck in it. If the float is sticking on its own try spraying some WD40 into the housing to free it up.
07-08-2005, 09:49 AM #6
Try using comressed air to try to dislodge anything that may be stuck in it. If the float is stuck on its own, try spraying WD40 into the housing to try and free it up.
1998 Mobius
310 HP PCM
SOLD
07-18-2005, 03:37 PM #7
Adding to the confusion.
I got the access plate off so I now have easy access to the bilge and switch. I tried cleaning the float switch, but it appeared that the float was not stuck. So I assumed it was in the electronics of the float. So I cut the wires from the float switch to "wherever it goes'. The bilge continues to run with the dashboard switch turned off.
So it would seem that either:
1. The dashbaord switch has some wierd short in it.
2. The circuit board behind the dash has a short
3. An open in the float switch tells the bilge to run?
In the mean time I have pulled the connector off the circuit board so the bilge will not run at all. At least this way I do not need to always be disconnecting the battery to stop the pump from draining the batt.
Anyone have any ideas I would appreciate it.
TIA
07-18-2005, 07:22 PM #8Senior Member
- Apr 2003
- Powhatan, VA
- 316
Yes, Dave, I'll bet I might be able to help.
Remember, I have the 99 outback, which is the stripped-down mobius that year.
10 days ago we had problems and replaced the original bilge pump with a Rule #750.
The original wasn't working on auto. Just on manual. Actually, had the reverse occured, it would have been by chance, based on the wiring mess I encounterd.
The original set-up ( I'll bet yours is the same ) is pretty cobbled-up.
Three wires from the dash, converted under the floor near the pump to a four-wire set-up. Plus, extension wires were grafted-in. For us, the crimp-on connectors corroded. One had fallen-off. The others pulled-free when tugged. The whole mess was wrapped with electrical tape from the factory. Based on what I saw, the wiring could possible fail and cause it so stay on all the time. Hard to explain, but check yours and see if I'm right. The other idea, smokedog, of flushing is legitimate, also.
Solution for us: Find the basic three-wire set-up, under the floor near the pump, before all the grafting crap. Cut there, and either install a new three-wire pump with built-in float, else, figure out the wiring ( its easy ) and reattach the old unit. Re-do the connections with new crimps. It'll last another few years!
The Rule 750 was about $45.00 at boaters world. Probably 0 markup or more. It pumps more volume than the original.
I struggled with this for 2 seasons before I got serious and fixed it.
To test the original float and pump, remove both and test on the bench with a meter, else, against a battery directly. Easy to remove and re-attach if need be.
Hope some of this helps.
07-18-2005, 11:39 PM #9
Thx Catdog. This pretty much agrees with what I am seeing. I did not unwind the electrical tape at the junction of the 4 wires. I was thinking that they might be using a special anticorosion sealant that I would not be able to replicate. If it is just electrical tape I think I can manage the works myself.
Hopefully this means I do not have to worry about the switch or the circuit board. I will give it a try this weekend.
07-25-2005, 10:38 PM #10
So I have now replaced the Mayfair 500 gph pump and automatic float switch with a new 750 gph Mayfair with new automatice switch. The new switch came with three wires, a black, a brown and a a brow with stripe. The old switch only had two wires (no black).
You guessed it - bilge still runs full time. I am not certain I have the wiring right. I connected black to balck, brown to brown, and stripe to stripe . I also reused the existing wiring and connections since they appeared secur and I thoought I could still cuthe them out if needed.
I am starting to think that it may be the dash switch. When I turn the bilge on from the dash the pumps seems to spin up faster.
I took a look behind the dash and was able to find the wire to pull so at least I am not disconnecting the battery all the time.
But I can not for the life of me figure out how to get that swtch out of the dash. Do I need to take the whole control pannel off? If so does it just pull off the swtiches. It looks like all the spade fitting on the switches is all that is holding the board to the dash.
Ideas?
Ballast Rocker Switch----Where to buy?
By Loonytik in forum General ChatReplies: 4Last Post: 05-04-2008, 01:37 AM -
Perko Switch or Battery Isolator
By jrich23 in forum General ChatReplies: 6Last Post: 06-29-2007, 06:07 PM -
stuck in storage!
By Smrtz in forum General ChatReplies: 6Last Post: 04-28-2006, 08:02 PM -
acc. switch load?
By dprime in forum Service & RepairReplies: 3Last Post: 09-22-2004, 05:47 AM -
nuetral safety switch
By redlob in forum General ChatReplies: 1Last Post: 10-11-2003, 11:06 PM
