Results 1 to 8 of 8
06-10-2012, 11:29 AM #1Junior Member
- May 2012
- 5
Changing Fuel Filter 06 Outback V
Any insight on the procedures or problems changing the fuel filter?
06-11-2012, 02:27 PM #2Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
Should be on the starboard wall right next to the v-drive. No issues, just use some sort of catch can for the fuel that will come out of the line when you disconnect it. I just took mine out then went down to the auto parts store for a replacement.
2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
06-12-2012, 12:46 PM #3Senior Member
- Jun 2008
- Eugene OR
- 1,786
I just replaced mine on an 08 OBV. Simple. Like mnpracing said just have somthing to catch the fuel. Also do not do it on a full tank. you will get more then what you want coming out of the hose.
06-12-2012, 01:11 PM #4
Only issue I had is it's really only a 1 beer job. I like it when it takes a little longer
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
06-12-2012, 02:42 PM #5
Sounds like you didn't do nearly enough "planning" or "post job analysis".
06-12-2012, 02:49 PM #6Senior Member
- Feb 2005
- Ottawa, Ontario, Canada
- 718
Wrap a rag around either the filter or the hose, whichever is lower. Some fuel will dribble out, back down the filter/hose and not into whatever container you use. be prepared to hang up that rag to dry immediately after (easy at home, not so much at some marinas).
2005 XLV, upgraded ballast, Comptech swivel wakeboard and hydrofoil racks, Monster cargo bimini
06-12-2012, 02:49 PM #7
I like to light it on fire and wave it around.
06-14-2012, 11:43 AM #8
Ensure you're finished your smoke before taking on this repair and service job!
2014 Centurion Carbon Pro
2004 Outback DD - SOLD
1995 Supra TSM6 Comp - SOLD
Stay STACKED & Pull HARD!!!
