Results 1 to 6 of 6
Thread: 12 volt oulet
    Aug 2005
    Default 12 volt oulet
    I have a 05 outback and my 2 12 volt outlets arent working. I can't figure out anything wrong with them. My next step is to tear out all the wiring but I don't really want to do that. Has anyone else had this similar problem?
    Milwaukee, Wisconsin
    Check the fuses.
    Aug 2005
    Where are the fuses located?
    May 2007
    Richmond, VA
    Page 62 of the '05 owners' manual provides the location of specific fuses. Link is below. However, it does not include the location(s) for the 12 volt outlets. Maybe the 12 volt outlets use inline fuses?
    http://www.moomba.com/downloads/owne.../moomba_05.pdf
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
    Aug 2010
    Acworth, GA
    Not sure about 05 but my 10 has circuit breakers for the 12V outlets, again up under dash, mine are the small breakers with the round popup button like those turkey timer things... but if I recall the buttons are white. MIght be labeled, it was pretty easy for me to find when I popped one using my manual LaunchPad ballast pump...
    Kraig - 2010 Outback V
    Aug 2005
    I'll check it out. Thanks
