Results 1 to 6 of 6
    May 2012
    Rockton, IL
    Default I need a prop size suggestion
    Hello,
    Hoping i can pull from the vast knowledge of the forum members. I have just become a Moomba owner and would like to purchase a new prop. When the boat was running(long story, hope to have resolved soon) i had a slight vibration, i'm assuming the prop is bent enough to be causing the issue, shaft looks straight while running a fake lake. Instead of having the current prop rebuild i thought i would just upgrade to an Acme prop.
    What size does everyone suggest for a 2001 Moomba Outback which will be used mainly for
    Wakeboarding?
    How much ballast do you run? Do you have the 310 motor?
    May 2012
    Rockton, IL
    only running 400 pounds of ballast with the 310 carb motor..
    2004 Moomba Mobius LS
    2001 Moomba Outback
    1990 Malibu Mystere
    Have a look at this thread. Consider giving Nettles a call. Eric at OJ can be extremely helpful as well.
    https://forum.moomba.com/showthread....hlight=nettles
    That's who I would recommend as well.
    07 LSV
    Irondequoit Bay, NY
    like i asked before just like you..it all depends on the fat sacs your running and things you want to do..and stated above and in my thread..just call nettles and the guys and they will give you the best advice
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
