Results 1 to 10 of 20
    Aug 2008
    Hilliard, Ohio
    Default Need help on Speaker Tower Install
    I have a 2006 LSV without tower speakers and just purchased a set. Getting ready to plan on the wiring. Going up the port side front tower leg. Upon inspecting the boat the tower support plate has a hole on it, but the fiberglass does not. Would the tower foot have a hole in it?
    Can I drill with the tower in place?
    If you have the larger 2+ inch diameter tower then yes, it has a hole in the foot. I drilled mine from the inside of the cubby. I can prolly find you a couple pictures if you like.
    Jan 2010
    North Texas
    What he said^. IMO, a step bit (unibit) works best. I had to make the hole on each side of mine larger, and really, if the hole in the boat had been drilled in the center of the tower leg plate hole it may not have been needed. My hole was nearly completely covered/blocked.
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
    Jul 2011
    Murrieta, CA
    For piece of mind I would remove the 4 bolts holding the tower foot in place and drill from the top side. That way you know the hole ends up in the correct spot. Make sure to feather out the gel coat edge to reduce potential cracking.
    I did this over the weekend and it took about 30 minutes to complete. I held the tower foot off the boat with a flat foam fender/bumper while I drilled.
    I had to enlarge the hole on the starboard side where the tower light wiring ran thru in order to fish the speaker wire through.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    You getting tower speakers man? I need to see it to believe it LOL
    Jul 2011
    Murrieta, CA
    I am saving for the exile setup but I got a temporary pair from a fellow forum member. Will have a pair of Polk 6.5s w an infinity amp w talkback mic for the tower.
    I need to practice driving the boat with music on do you will be happier when I drive for you.😃
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
    Pittsboro, NC
    I have a few pics of my tower speaker and wire install, if you are interested, its under my stereo album install. May or may not be helpful.
    Patrick
    5 light- light bar.
    2015 RAM 3500HD Dually 6.7 Diesel w/ Aisin 6 speed tranny
    Live life today!
    Be sure and read through Al's sticky on how to install on the LSV with no visible speaker wires here:
    https://forum.moomba.com/showthread....-Speaker-Wires
    May 2011
    Fort Worth
    I drilled like Mike did... no issues what-so-ever.
    '08 Mobius LS
    Aug 2008
    Hilliard, Ohio
    Followed what Mike said, it worked. Just finished the install. Thanks Guys
    For $550 at best buy they sound good and I think the mic will lots of use teaching new boarders this summer.
