Thread: pump for wake plate
07-05-2005, 12:40 AM #1Junior Member
- Jun 2005
- 5
pump for wake plate
can someone tell me where the fluid pump is located for the wake plate if you order it as an option from the factory? thanks!
07-06-2005, 01:53 PM #2Member
- Jul 2004
- Lake Elmo, MN
- 81
Replying to Topic 'pump for wake plate'
The install of my wake plate was missed at the factory, so the dealer installed after delivery. I assume they put it in the same place as the factory would. It is installed in the drivers side rear compartment on my LSV. It sits in the back corner closest the engine.
07-10-2005, 12:46 AM #3Junior Member
- Jun 2005
- 5
thanks, but I am interested in hearing from someone with an outback with the fact install on the pump.
07-12-2005, 11:10 AM #4Senior Member
- Jul 2003
- Carson City, NV
- 157
Sweet, Open up your back ski locker and take the floor of the trunk out. You'll have to remove a couple screws. Then you can follow the tubing coming through the transom right to the pump. Should be located on one side of the fuel tank. You can't miss it.
07-13-2005, 09:00 AM #5Junior Member
- Jun 2005
- 5
Thank you!
Wake plate for LS
By mobyatBelews in forum General ChatReplies: 9Last Post: 02-28-2009, 10:58 AM -
Wake Plate
By Pike in forum General ChatReplies: 4Last Post: 04-16-2007, 11:57 PM -
Wake Plate
By YellowMoomba0 in forum Skiing & SlalomReplies: 4Last Post: 06-23-2006, 03:31 PM -
Wake plate
By clark in forum Wakeboarding | WakeskatingReplies: 2Last Post: 01-27-2005, 10:51 PM -
Wake Plate
By latchkey in forum Wakeboarding | WakeskatingReplies: 10Last Post: 06-11-2004, 11:50 PM
