Results 1 to 10 of 12
    Aug 2009
    montreal
    Default Rule Aerator Pump 700 GPH
    I notices that my Rule Aerator Pump 700 GPH (front pump to empty ballast ) is crack. Can someone tell me is this is the right part before I order a new one
    http://www.jamestowndistributors.com...PH+Bilge+Pump#photo(1).jpgphoto.jpg
    nope that is a bilge pump Go to walmart and get a tsunami 800 gph or your dealer may have some rule pumps the left over.
    or try this site if you want rule.
    http://www.cgedwards.com/Rule/rule03.html
    Apr 2011
    That is not the right pump. That is a bilge pump. You need a pump that has an inlet and 3/4" outlet. Have a look at the 800 gph Tsunami pumps on wakemakers.com. They are cheap and decent replacements for that pump.
    Aug 2009
    montreal
    so this should do the job, Right ?
    http://www.wakemakers.com/attwood-ts...-pump-800.html
    Apr 2011
    Yeah that's what I used to replace the stock 700gph pumps. You may have to order a straight connection. The elbow style that it comes with did not work in my 03 LSV.
    Aug 2009
    montreal
    Thank you guys
    Jan 2009
    Bennett NC
    Did this pump come with the same type plug in?
    Quote Originally Posted by 4fish4 View Post
    2007 Moomba Outback V
    2015 F-250 PSD CC
    2012 Fuse 40 T-bar
    Sky Ski Le-38
    XXX front wing
    UFO rear wing
    Evo tower
    Quote Originally Posted by murraymoomba View Post
    No you can splice the plug off the rule or order te deutsch plugs from batts racing and solder yourself.
    http://www.deutschconnector.com/prod...es_connectors/
    Jul 2009
    Spokane, WA
    I think I might have the same issue with my ski locker drain pump - I always seem to have water in the ski locker after using it and the IBS.
    Do you guys know if the Tsunami will work with the stock aluminum Rule pump mount that comes with these boats? I'd like to swap this pump out today if possible, but the only place I've found for the Tsunami mount is Wakemakers.
    2015 Supra SC400
    08 LSV - Sold
    Go big, or go home.
    Aug 2008
    Cottage Grove, MN
    Quote Originally Posted by squeeg333 View Post
    It will drain better without the mount, just let it lay in the locker.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
