Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 62
Thread: Loose steering
  1. #31
    Default Loose steering
    Changed the gear box that connects the to the steering rack on the cable and the cable and steering is still sloppy. No luck
    Sent from my iPhone
  2. #32
    Jul 2012
    Cumming Ga
    I have the same issue with my boat, could it be because the cable itself is flexing, it seems like the cable is really long and I would think over that distance if it were not strapped down good it would move. I may be way off here I don't know. Next time I get my boat out of the water I will play and see
    Sent from my iPhone
  3. #33
    Well i have been behind the wheel of some other boats recently and my buddies Axis A20 does the same thing as well as my buddies Supra 21V so I guess this is just normal. The best way to fix this is not to drive a new SA so you never know any different!
  4. #34
    You would think that something that loosens up could just be tightened up.
    Nov 2009
    Gatineau, Quebec
    I found something loose on my 2012 LSV ill take a pic I bet its your issue to.
    2012 Mobius LSV
    05 Outback LS SOLD
  6. #36
    Nov 2009
    Gatineau, Quebec
    Here's what I did, I removed the part link or something what ever it's called it seems under high load the part opens up and the bushing plays back and forth , I removed it and squeezed it back together .
    Hope this helps
    2012 Mobius LSV
    05 Outback LS SOLD
  7. #37
    Nov 2009
    Gatineau, Quebec
    I new something was wrong when I couldn't hold a strait line pulling a boarder . Issue was solved
    2012 Mobius LSV
    05 Outback LS SOLD
  8. #38
    Thanks, I will check this out next chance I get!
  9. #39
    Ditto! Worth a shot.
    Nov 2009
    Gatineau, Quebec
    I still had a bit of play and found these two Allen keys loose
    2012 Mobius LSV
    05 Outback LS SOLD
