Results 1 to 10 of 14
05-21-2012, 08:55 PM #1
Boatmate replacement LED tail/turn signal
Odd thing happening on my boatmate trailer LED turn/tail light, the left turn signal is not working but the tail light is on (you should all laugh a little now because I try "not" to take a route with a left turn as much as I can). So had my father take a look at it with his volt meter and he checked both the receiver adapter wiring as well as the trailer light and told me that I must need a new unit for the tail/turn signal.
So I go on boatmate's replacement parts website and look at their LED lights and the only thing I find that matches is this: http://www.boatmateparts.com/product...-t-60-1033.htm
but that is in an AMBER casing and my light is RED. I didn't look to much into the light so I don't know whether or not, nor how easy it would be, to swap the red casing onto the new light with the amber casing. I just thought I would find a direct replacement. Called boatmate earlier and there phone customer service is pretty lame, basically sends you to the service/parts managers voicemail and he tells you on the message to email him. I emailed them tonight and figured I ask around here to see if anyone else has had to replace these lights and if so did you go through boatmateparts and what was your experience and if not how'd you replace it?
Justin2008 Supra 21V-Currently For Sale
05-21-2012, 09:01 PM #2Senior Member
- Jun 2008
- 143
Yeah, Boatmate only has Jerry from what I have ever gathered. He is good to work with, but can be hard to reach. I just recently replaced almost all of my lights, and I did so from trailerpartsdepot.com. Same connection and size as original parts, but about half the price with pretty quick delivery. As far as swapping out the lens, I would suggest against it, if it is even possible. It may be hard to duplicate the waterproofing once you break the seal. It is a really easy DIY, but hit me up if you need any help.
2022 Mojo
05-21-2012, 09:15 PM #3
I think you might even be able to find a replacement at Wallyworld.
05-21-2012, 11:03 PM #4
you just need 1?
I might have one in garageBrad
2006 Moomba Mobius LSV sold
2004 Outback sold
05-21-2012, 11:11 PM #5
I'm going to check trailerpartsdepot, thanks dubwake. Wallyworld? I don't think so at least with the ones up here. There's a very small "boating section" in the walmarts around here. They def. do not carry LED trailer lights.
Yeah I need just one.2008 Supra 21V-Currently For Sale
05-21-2012, 11:15 PM #6
Not in the boating section. In the trailering section where they have the hitches, etc.
05-21-2012, 11:18 PM #7
All I have are incandescent off my 06 trailer.
Brad
2004 Outback sold
05-22-2012, 01:18 AM #8
I would check trailer fab shops and farm accessory places. I would think all LED lights would be sealed as they have the electronics that hate water.
1998 Mobius
310 HP PCM
SOLD
05-22-2012, 07:29 AM #9
Justin, try to remove that lense and see if there is a name on it, then google it and find a retailer. I had to do that on a fishing boat trailer and turned out wallyworld had it.
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
05-22-2012, 07:37 AM #10
You have "tractor supply" near you? Around here they have pretty much any trailer part you need
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
