Results 1 to 10 of 16
    Jun 2011
    Default Outback Aerial FreeRide Installed
    Here's the latest work on the Outback. Tower is solid, jury is still out until we're able to ride it though. I installed myself, besides having 2 helpers put it up once I had drilled and installed the rear mounts. Fishing the speaker and 360 wires was a pain!
    Brandon
    2000 Moomba Outback LS
    2001 American Skier LazAir Edition
    1991 Ski Tastic Inboard
    Busy day, Brandon! Looks great but you should have installed that hot tub first so you had a place to relax after all the work on the boat.
    Feb 2008
    Traverse City, MI
    That looks phenomenal!
    2013 Outback V
    Apr 2011
    NY
    Looks awesome! Good choice.
    '06 Outback - Gone but not forgotten
    '13 Mojo
    Feb 2009
    Wausau, WI
    With all the work you have put in, its doesn't look like a '00. Looks really good.
    Matt
    Quote Originally Posted by Hoopskier View Post
    Agreed, looks great.
    May 2010
    Lynchburg, Va
    Looks great man! How did you bring the wires through the gel coat?
    1998 Moomba Outback - Indmar Assualt - Black Aerial Assault Tower - 10 inch KENWOOD Sub, amp, and Head unit - ACME prop - New interior - de-stickered - re-finished Gel-coat
    Aug 2009
    Montana
    Looks great.
    Nice work
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Jun 2011
    Thanks for all the comments guys, I'm pretty stoked with how it's turned out! Still have quite a few details to finish up, but I should have it back on the water within a couple weeks.
    Drew, I wish! That hot tub is Michigan bound next weekend, bought it for our family lake cabin.
    Outback98, I haven't tackled the wiring thru the hull yet. I'm going to look at it today, may try and run it thru some black hose rather than the cheapo plastic wire loom stuff. Will update with some pics once I figure it out
    Brandon
    May 2010
    Lynchburg, Va
    check out this nice little quick disconnect. I may go this route. It's a brand called Neutrik.
