Results 1 to 10 of 32
Thread: Dual Batt Set-Up??
05-18-2012, 10:36 AM #1
Dual Batt Set-Up??
Im starting on my stereo wiring and double battery set up with a pergo switch by the drivers side panel. Whats the best way for me to set this up? And what NOT to do?? Heres my set-up. Thanks JetAmp Rack 1.jpgBattery Set-up.JPG
89' Comp Resto:
http://supraboats.com/bbs/showthread.php?t=8193
Riding and Mod pic's:
http://www.supraboats.com/bbs/album.php?albumid=86
89' Supra/Custom Tower & Interior/Swivel Racks
4 Blade-14X14/1600 lbs Ballast
Roswell Bar/Led's/Krypt 6.5 HLCD's/Krypt 4200 Eq
JL-PPI Amps 1750 Watts/Kicker Interiors/L7 Kicker Sub
05-18-2012, 10:37 AM #2
Oh, how do you like those zoomie header pipes I added? lol
89' Comp Resto:
05-18-2012, 11:11 AM #3
whatever you do, don't use a pergo switch.... spend the cash for a real hardwood switch..
I'd run it up and over if you can. keep wiring off the floor if possible.
that ppi amp looks nice. I really liked their stuff. love to have a pair of pro-mos425's in my boat'06 Supra Launch 20SSV-gone but never forgotten
05-18-2012, 11:23 AM #4
Interested to see the responses here, I JUST finished my stereo setup and I think we are pretty much identical now. 3 amps and I have the Perko in the garage waiting for me to buy a second batter, cable, and install...
05-18-2012, 11:31 AM #5
Just remember that weight placement affects the wake and some batteries weigh around 50lbs. I'd think about where I need the weight (nose/middle, center/side) in combination with your ballast, cooler, seating, etc.
05-18-2012, 11:56 AM #6
Exactly on the battery placement. The battery location is driver off-set weight. Whats the deal with pergo?? Probably 80-90% of boats have a pergo?? And whats a hardwood switch??
89' Comp Resto:
05-18-2012, 12:25 PM #7
And what size cable should I use going to the batterys?? 0-4-8??
89' Comp Resto:
05-18-2012, 12:59 PM #8
I'd agree with sandm, def go with hardwood over pergo. Pergo looks nice at first, but after a while you will wish you had just gone with the real deal.
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
05-18-2012, 01:02 PM #9
guess that one flew below the knees and over the head. it's a perko switch. I'll let you figure the rest out
I'd use 4 for the amps to a distro block, then use either 4 or 8, depending on what the owners manual calls for. assuming that you are using a distro block. if you are wiring each amp directly to the battery or perko, then use what the manual calls for. every amp will be different. as for wiring to the switch, not sure what the manual recommends, but you can't have too much. make sure you use a good quality cable and solid connections. that's where most issues pop up.'06 Supra Launch 20SSV-gone but never forgotten
05-18-2012, 02:04 PM #10
Oh, I did do Pergo huh? lol
89' Comp Resto:
