Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Props
    Irondequoit Bay, NY
    Default Props
    im new to the whole props and what one does what..i have my 04 outback and all we do on it is wakeboard and tube..no skiing. Soo i want to set it up the best i can with some sacs and a better prop (if i have to) is there a better prop? or should i leave it stock?
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Jul 2009
    Cleveland, Tn
    I have an Acme 913 for sale in classified section. That's what the people at nettles props told me I needed of wakeboarding/surfing. No sure if it would fit and outback though. I got it for my 09 LS but never put it on because I got a Mojo.
    2012 Mojo
    2009 LS (SOLD!!!)
    2010 Tundra 5.7 Crewmax 4X4
    Feb 2009
    Wausau, WI
    I'll throw in my .02
    I have 2 props for my outback. Both props are OJ Legends, which are cast. The newer props are CNC machined which are more accurate to the specs. Both of my props are 13x13. One prop is 3 blade, the other is 4 blade. I have a preference to my 3 blade.
    The 3 blade is a decent for about everything. Skiing, wakeboarding, tubing. I find my 3 blade is more fuel efficient. If you run a heavy boat most of the time, it can be a little slow on the start. I run some ballast (800#) sometimes, and still use this prop.
    The 4 blade, is better for a the heavy boat. Better out of the hole. Holds slower speeds better. Uses more fuel. Little top end loss.
    Purchased my boat used with 4 blade. I put a 3 blade on. Kept the 4 blade as a spare. I have switch back and forth between props and always end up back at my 3 blade. I know there are other props, the newer CNC props the are probably better all around than what I have.
    Matt
    Irondequoit Bay, NY
    ok i was just wondering bacause i see alot of people on here talk about acme props and others..i didnt know if like there was a different pitch on some and that made a better wake or do something else that would help the boat out to make wakeboarding better
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Belton, Texas
    What was the verdict on the acme 1235 on an 09 LSV. You Da Man offered me a sweet deal on his 1235 after he got the cinco blade but when we looked the 1235 didn't have a whole lot of clearance from the bottom bar of trailer. I was bummed when we decided it wouldn't safely fit
    2009 Moomba Mobius LSV
    Thought al did a test and the 1847 was the best alt for the 1235 with clearance.
    Sent from my ADR6300 using Tapatalk
    Jan 2003
    Minnesota and Wisconsin
    What is wrong with your current prop?
    A good prop will run you $300-$400. Having said that - it is always wise to have a spare, just make sure you get a puller and know how to use it.
    http://bensonwdby.home.comcast.net/
    Feb 2012
    St. Albert, Alberta, Canada
    Here's my ACME 1235 on my '10 LSV w/boatmate trailer. ImageUploadedByTapatalk1337171829.414437.jpgImageUploadedByTapatalk1337171883.563550.jpgImageUploadedByTapatalk1337171910.228733.jpg
    2010 MOOMBA LSV
    340 CAT
    ACME 1235
    3100#'s
    Belton, Texas
    We didn't get anymore than 1/2 inch clearance from bottom bar on my 09. Didn't actually install it just held
    It up by hand
    Sent from my home phone..
    Feb 2009
    Wausau, WI
    For moto's boat; in his signature is does not specify a V-drive. The V-drive and direct drive use different drive shaft sizes, 1" vs 1 1/8".
    I would try what you have on the boat. Also you will want to know what you have on the boat before you change to anything else.
    3 blade or 4 blade. pitch vs diameter. CNC machined vs cast. There are a few variables. Give the ACME or OJ or Nettle props a call.
    Matt
