Results 1 to 5 of 5
05-14-2012, 03:27 PM #1Junior Member
- May 2012
- 4
Need a little help wiring speakers to amps...
So I finally gathered all the amps and speakers I am going to use.
I have two exile sx65Q surf speakers
Rated at 125W RMS/250W Max 4 ohms
I have four exile sx65m cabin speakers
Rated at 100W RMS/250W Max 4 ohms
I have a Kicker 450.2 amp
4 ohms: 150 watts x 2 chan.
2 ohms: 225 watts x 2 chan.
Bridged, 4 ohms: 450 watts x 1 chan.
I have a Boston Acoustics gt-2200
4 ohms: 200 watts x 2 chan.
2 ohms: 350 watts x 2 chan.
Bridged, 4 ohms: 700 watts x 1 chan.
Bridged, 2 ohms: 900 watts x 1 chan.
What would be the best and most efficient way to hook these speakers up to these amps(a diagram would be awesome).
Thanks for all the help y'all have given!!
05-14-2012, 03:52 PM #2
based on what you have, I'd wire the tower surf speakers to the boston amp. it's pushing the most to a 4ohm load, wire it as a standard 2ch 2speaker setup.
run the 4 exiles to the kicker amp and run it as 2 speakers per channel dropped to a 2ohm load. wire them in parallel connecting the 2 positive leads per side to the amps positive channel and same with the negative leads on each side..
my .02 fwiw..'06 Supra Launch 20SSV-gone but never forgotten
05-14-2012, 05:06 PM #3Junior Member
- May 2012
- 4
Like this for the cabin speakers?
05-14-2012, 05:22 PM #4
05-15-2012, 04:34 PM #5Junior Member
- May 2012
- 4
Thanks, i figured i would spread the question around...
